What is the best option if I want to create an email using my domain name?
edited March 2022 in General
I have a domain name that ends with top and I want to make a mailbox with it. I know many platforms have this kind of service, but I want someone with experience to help me choose.
My daily requirement is to send and receive hundreds of emails every day, and I don't clean my mailbox very often. (Used as a notification email for a private forum)
  • @spiritlhl said:
    I know that some platforms can bind a domain name and then use the domain email service, but I would like to get some opinions from others to help me choose.
    It's not entirely clear what you're asking
    If you need to send hundreds of emails everyday, you'd do best to use a mail-sending service like Amazon SES or MailChimp
  • It's not entirely clear what you're asking
    I modified my description. Thanks for your suggestions, I will try them all.
    Do you want both outgoing and incoming emails?
  • mxroute.com. No brainer.
    Thanked by (1)Ganonk
    I'm sure MX Route can handle it, but I can also see hundreds of forum email notifications a day stacking up in a mailbox being the sort of thing Jar might consider routing into a spam filter.
  • edited March 2022
    Indeed.
    For ordinary email usage, MXroute is a great choice, but above, I took the OP's usage not to be ordinary email usage. (MXroute also has a limit of 300 emails per hour.)
  • edited March 2022
    Mind you multiple spam filters penalise the .top TLD during spam scores, including by MXRoute's themselves. Generally cheaper domains and e-mail don't play well due to the higher risk.
    Otherwise, cheapest option would be MXRoute which gives you both incoming and outgoing emails, although 300/hour per account, and if you abuse this you will be booted. If you need more, move on to Amazon SES or SendGrid.
    Perfect! I don't think its limitations affect my usage.
  • edited March 2022
    Most of them are outgoing emails.
    Mailing lists or forum notifications and such, Amazon SES.
    Then combine it with a shared hosting account somewhere for the regular emails.
    Thanked by (1)spiritlhl
  • Thanks to the advice of experienced people, my problem was solved.
    Thanked by (1)ysdx
