Looking for a budget VDS/Dedi with either 4C/8T or 8C/8T
Hey all,
I'd like to get a VDS or Dedi with some pretty... odd requirements.
Max I'd like to spend would be around $20/mo. OK with monthly or yearly billing.
CPU: Any x86_64 cpu with virtualization support/passthrough , 4 cores with SMT or 8 cores without SMT at a minimum
RAM: 8GB or more
Disk: Any type, 160GB or more
Bandwidth: Any
Traffic: Any
IPv4: 1 or more
IPv6: Any
Best deal I've found so far is Dr. Server's Atom C2750 Dedi for $16/mo.
Thanks in advance!
https://www.kimsufi.com/us/en/order/kimsufi.xml?reference=2201sk070
$20.99 - it's 4c/4t but it would blow that atom out of the water
or with hyperthreading, for $2 more:
SSD: https://www.kimsufi.com/us/en/order/kimsufi.xml?reference=2201sk081
HDD: https://www.kimsufi.com/us/en/order/kimsufi.xml?reference=2201sk070
These of course have setup fees unfortunately
Hi @CamoYoshi! If you wish, I am super delighted to host you for free. Or you can make a small monthly contribution. Whatever you like can be arranged. Best wishes from Mexico! 🏜️
MetalVPS
Hi @CamoYoshi
I can offer you:
AMD EPYC™ L
CPU: 4 Cores / 8 Threads
RAM: 32 GB
STORAGE: 400 GB
UPLINK: 1 Gbit/s
UNMETERED INCOMING TRAFFIC
Outgoing Traffic: 32 TB per month
IPv4: 1
IPv6: /64 Subnet
Dronten, The Netherlands
KVM with AMD-V
33,00 € 16,50 € / monthly exclusive VAT, if you are from the EU, VAT applies ORDER HERE!
97,00 € 48,50 € / quarterly exclusive VAT, if you are from the EU, VAT applies ORDER HERE!
193,00 € 96,50 € / semi-annually exclusive VAT, if you are from the EU, VAT applies ORDER HERE!
385,00 € 192,50 € / annually exclusive VAT, if you are from the EU, VAT applies ORDER HERE!
For more Information, please check our offer thread: https://talk.lowendspirit.com/discussion/3957/50-off-ryzen-epyc-vds-nl-alipay-btc-cc-pp-unmetered-traffic-incoming/p1
If you need less resources, AMD EPYC™ M might fit your needs.
server-factory.com
that's a very nice offer.
what spec a 8€/m brings?
Thanks, 8,50€/m bring you the AMD EPYC™ M
server-factory.com
and because we are already family?
That price is for LES family
server-factory.com
Generous offer! However I need to run Proxmox, so I don't think I can take you up on this really. But thank you for offering nonetheless
Great offer! Might go with this one.
@CamoYoshi a few Customers running Proxmox are very happy with us
server-factory.com
Use code "YBDX4U70Q" while ordering the 240 GB SSD server and bring it to $12/mo.
Thank you to all who provided offers here. I ended up going with @mxmla 's services at this time.
