Maybe geekbench was having issues with their site/ downloads or something this morning? Not sure. Just ran a test and it went fine, can you guys give it another go and see if the issue is resolved?
it just got fixed like 5mins ago.
EDIT: no others failed again on GB4
GB5 works fine here now, I don't use GB4 anymore, so can't comment on that (nor really care about that :-P)
Some issues with their CDN I believe.
GB4 working now! my anxiety is over.
VirMach Tokyo
Oracle Cloud free Singapore
RackNerd Amsterdam
LiteServer
OVH Public-Cloud, Discovery D2-8 , Gravelines1
Unmetered in SG for $9 monthly
It’s from an old LEB offer, can’t believe the coupon works
Node:
VM:
Need to think about how to improve 4k block speed and CPU bench on multicore...It's slightly lower.
Continuing to work on performance
Hmmm, your disk perf seems kinda low. Here's mine Racknerd Amsterdam from March Madness
That's probably coz its installed in ide and not virtio.
VirMach Ryzen Phoenix (Internap)
VirMach Xeon San Jose (ColoCrossing)
VirMach Ryzen San Jose (Internap)
VirMach Xeon Buffalo (ColoCrossing)
HostHatch 10TB Black Friday Storage VM Amsterdam
Virmach Tokyo Ryzen 2560mb
Struggling to decide which dedi to keep. Looking to host a few websites, SQL and a handful of game servers;
OVH - ~£54p/m
Mevspace - ~£31 p/m
@mevspace looks like clear winner, unless you are hard pressed on the ram requirements.
I was thinking the same, it's just difficult to cancel the OVH one with the high ram/nvme!
VPS reviews and benchmarks |
Also tempting.. but one will definitely go unused!
be a vps provider on the ovh server, make it for cheap. i know i will want one
I think you should keep the mevspace and transfer the ovh one to me
A thought like this went through my mind, but purely on the gameserver front. I wouldn't want to become a VPS host to be honest..
Could come to this
dont let the OVH go to waste, maybe @bruh21 could help LES make better use of it?
ColoCrossing E3 Bare Metal (Buffalo)
Kimsufi KS-07 (BHS)
SYS SAT-02 (GRA)
OVH BFSTOR 2022 (VIN)
OVH KS-LE (BHS)
VirMach Tokyo SPECIAL 4096 (TYOC039)
How much does CC charge for that?
Sat Apr 9 05:53:13 UTC 2022
Processor : Intel(R) Xeon(R) CPU D-1521 @ 2.40GHz
CPU cores : 8 @ 1835.905 MHz
AES-NI : ✔ Enabled
RAM : 31.2 GiB
Swap : 3.0 GiB
Disk : 65.2 TiB <<<<<<<<<-------------- WOW
