Can only CentOS 7 be installed on this machine?
I tried installing Ubuntu 20.04, Ubuntu 18.04, Debian 11, Centos 8, and Windows Server 2022(evaluation mode). Only Centos 7 is successfully powered on. Is that normal?
And after the boot I did not operate anything, broadband traffic in inexplicable consumption.
I want to install Ubuntu 20.04 on my machine
Templates are broken. I'd suggest you to install AlmaLinux 8 (to enable CPU passthrough/AES-NI), then use the netboot.xyz ISO to reinstall with your desired OS.
@Jab said: @VirMach please double check those adjusted invoices dates - a lot of people reports it's set to 7.04.2022 (aka today, not 2023) and if your billing system gonna charge that you will have shit ton of new angry customers and chargebacks ^.-
If your automagically billing is disabled just ignore me
Also, would you be able to delegate the block's auth to a customer's NS?
For domain registrations, create an account at Dynadot (ref) and spend $9.99 within 48 hours to receive $5 DynaDollars! Looking for cost-effective Managed/Anycast/DDoS-Protected/Geo DNS Services? Try ClouDNS (aff).
We're refraining from offering any customizations or anything else, and limiting a lot of custom requests for some time until everyone is first migrated to Ryzen. We just wouldn't be able to handle the ticket load from all of our customers asking us all these things at once, I hope you understand and I wish it was possible.
Tokyo is about to be put behind a pay wall, as in, there will be a setup fee for Tokyo as soon as our sale gets posted on OGF. So it's last call to order Tokyo without paying this setup fee.
hello, ip can't connect. Unable to boot after reinstalling the system. Please fix. Thanks!
service order#837558
Invoice 1413470
@VirMach
Order #560836
OrderNumber 8477795567
Invoice #1415112
Thanks.
谢谢,我明天白天进行一下尝试。
Saw this and found my old Intel VM doesn't have AES-NI, and reinstalling with template enabled that. Thanks for the hint!
Piss off with this shit! It's an English forum not Hostloc. Don't make this into another LET !
No need to use strong language.
I will make an update to the rules in a minute.
https://clients.mrvm.net
You may (may not?) notice that I don't revert to strong language very often. Usually only to make a strong point.
Thats why I so gently remind you to find your inner peace and be one with the universe.
Ice cream??
I scream frequently (inside).
managed to install debian 11 via netboot.
TYOC040 seems faster now hitting 200mbps.
However kernel panic still can happen when running YABS.
^ must be the coder's fault!
TYOC039 network is still not in perfect condition, but I hope it will stabilize in time!
yes i get anxiety when no YABS runs well in a day.
picking up now
Your bandwidth has doubled tripled 😉
TYOC040 is Ryzennnnnnnn
Got mine yesterday and has been using it ever since. There were some trouble when installing OS but all worked fine now.
YABS :
# Yet-Another-Bench-Script #
# v2022-02-18 #
@Virmach After the incidents on your recent sales thread on OGF, I was wondering if you would ever do a sale there.
What were the incidents ? (Response via pm okay, or in Cest Pit, thanks)
VPS reviews and benchmarks |
@VirMach Hello,please activate Invoice #1413533.
Thanks.
What are you installing?
Is this still an issue?
I have amnesia so I'm sure I will but I'll instantly start getting flashbacks and yell at myself when I realize the same thing happened again.
Is the /64 IPv6 upon request?
Just referring to NL.
We'll add a button to add /64 IPv6 blocks later, or at least that's the current plan.
Order #560658
OrderNumber 7159836566
Invoice #1414526
