1910121415277
  • edited April 2022
    Hi ,my order sn is 4885747348,thanks.
  • @ywnsya said:
    Order #561117
    Thanks
    VIRMACH MUST BE THE BEST
    So Sorry, i forgot to write down the order SN
    invoice #1415830
    Order #561117
    Account [email protected]
    hope the best VIRMACH can give me this opportunity
    edited April 2022
    work is being done on TYOC040 and its finally working, fio completed without kernel panic:
    Read       | 413.25 MB/s (103.3k) | 1.43 GB/s    (22.3k)
    Write      | 414.34 MB/s (103.5k) | 1.44 GB/s    (22.5k)
    Total      | 827.60 MB/s (206.9k) | 2.87 GB/s    (44.8k)
    Read       | 3.96 GB/s     (7.7k) | 3.22 GB/s     (3.1k)
    Write      | 4.17 GB/s     (8.1k) | 3.43 GB/s     (3.3k)
    Total      | 8.14 GB/s    (15.9k) | 6.65 GB/s     (6.5k)
    Thanked by (1)risturiz
  • yokowasisyokowasis Services Provider
    Is there a way to reinstall Windows OS without waiting for technical support ?
    netboot?
    @cybertech said:
    netboot?
    netboot ?
    edited April 2022
    @yokowasis said:
    @cybertech said:
    netboot?
    netboot ?
    netboot.xyz
    you should have the ISO in the list.
    mine has quite a few windows ISOs as well
  • edited April 2022
    [Ticket ID: 495525]
    Order #560916
    invoice #1415210
    Thanks
    I thought I should add because I didn't see the order number
  • Hi @VirMach
    I placed an SPECIAL 4096 order on 07th April. At this period, your server was suffered by high DDoS attack so Cloudflare showed me the timeout notice after placing this order & I couldn't note it to put it to you.
    I can only note the Invoice ID & not see the Order ID existing anywhere.
    My Invoice ID is #1414080 (Place on 07th April 2022)
    My billing email is [email protected]
    If it's acceptable, can I make a refund & re-order a new one ?
    Thank you in advance & Hope you have a great day !
  • @kaokao2222 said: VIRMACH MUST BE THE BEST
    Looks like the new Hostloc mantra. :/
  • @yokowasis said:
    @cybertech said:
    netboot?
    netboot ?
    Surprised at you, for not knowing about this. You've hung around long enough now. ;)
    What do you mean, bro
  • It wisnae me! A big boy done it and ran away.
  • @tetech said:
    @tetech said: Your renewal price will be increased by $5 according to the first post in this thread:
    Did (s)he generate that ticket. It looks like a system generated.
    According to the quote, it is the posting of the ticket number which incurs the cost, not the generation of it.
    I personally would expect this to be okay. It's "requested-adjacent". They needed activation and just included every bit of information they had. ;-)
    All order IDs should be activated. If you provided order ID and it's not activated, let me know. If you provided anything other than order ID, I can't immediately activate it right now but I'll probably go through each location in bulk anyway at some point in time so you'll receive your service most likely, you just have to be more patient.
    Thanked by (1)kaokao2222
  • One slightly off topic question, saw people mentioning migration of San Jose nodes (SJKVM4, 12, etc.), but no migration email for me so far (mine's on SJKVM3), will other nodes get migrated sometime in the future?
    Currently thinking about requesting a location change due to mediocre download speed from other locations (upload is fine), but will hold off for now if there's planned migration.
  • FrankZFrankZ Moderator
    @NaGi said: Why does my VPS start without any response,SSH cannot be connected#560658
    I would expect that your VPS had a problem with the O/S install. You should connect by VNC using TightVNC or similar VNC program, not the html5VNC in the panel, and see why you VPS is not available.
    LES • AboutDonateRulesSupport
  • Hello @VirMach, please active my order ID 6781701556.
    Thank you!
    @VirMach
    Hello,my vps is always display in vnc:
    Boot failed: not a bootable disk.
  • @flips said:
    I pre-ordered a Special 2560 in the NL earlier (in March).
    It's pending ... Interestingly the hostname is Hurtful Near ... :# =)
    Good to see you here, @VirMach ! Great offers!
    I pre-ordered this back when status was SHIPPING or SHIPPED (don't recall exactly). From comments in this thread, it seems NL/AMS should be active by now? (No particular rush on my part, just curious, and hope I'm not forgotten ...) 😅🤔😎
  • @goldmonkey said: Boot failed: not a bootable disk.
    Go to control panel and reinstall. It may be fixed now but when I tried to install Debian 11, I got that error because of some trouble with the installer. I installed Debian 10 instead and then upgraded with apt-get, and that worked.
  • edited April 2022
    View Ticket #669693
    Order #560576
    Invoice #1414425
    How long do I have to wait?
    Thank you!
    @VirMach
  • @ovzlacom said:
    View Ticket #669693
    Order #560576
    Invoice #1414425
    Thank you!
    @VirMach
    Don't be impatient - just wait.
  • Is anyone else getting nonstop rate limited by Cloudflare? I always get the rate-limit error after trying to log into the client area...
    Haven't had a problem so far this weekend. Just logged in and poked around to be sure nothing had changed.
    edited April 2022
    almalinux 8.5 (graphical) installer does not boot, both ISO and via netboot.
    on ISO mount it just stays offline
    on netboot it downloads the image but gets stuck on some initialization
  • order number:4089029737 thanks a lot
  • @VirMach pls add two new orders:
    Order Number is: 3255502368
    Order Number is: 9315313493
  • Hi again
