11213151718277
    @goldmonkey said:
    Hello,But no matter what OS I use, it's the same result.
    Thanks.
    Debian 11 is fixed.
    Thanked by (2)FrankZ AlwaysSkint
    @gebilaowang said: So, I still hope that the person in charge of @VirMach company should be aware of the emergence of this problem. And can tell you that the so-called exclusive offer links are now being moved to other sites by people in this forum. If you can read Chinese, you can go to the following link to check, of course, you may be able to use a text translator.
    I mean we've always had this problem. Anyone can link anything they want on the internet and claim for it to be whatever they say, at that point it's up to the user to verify the information. For example if I randomly linked https://billing.virmach.com/cart.php?a=add&pid=199&billingcycle=biennially somewhere then you wouldn't see the information on the offer page (https://virmach.com/special-offers/) or this thread where it states it's for LES members. However, you also wouldn't see what you're even buying. It just says Special 768. What if it's a 768MB bandwidth special? You just don't know then.
    Or people can still lie and make claims such as it's the 768MB special with 200GB disk and 10TB bandwidth, or omit details to make it sound better or worse.
  • edited April 2022
    Okay, to be fair, buying through a completely unknown rando affiliate link is probably not a Good Plan (tm) either. You can protect yourself by just not doing this. You truly are equally at fault ( just my opinion ).
    This is a very common purchase method, almost all VPS providers have aff, and it can correctly navigate to the official website of the VPS merchant.This means that it is officially recognized and successfully paid through it to the VPS merchant's account and not someone else's account.
    @risturiz said:
    Yes, thanks for confirm that... I see some packet loss and high cpu steal ( i'm not sure but this node is new? )
    Graph have white spaces because packet loss... So i know its not my VPS only :-) ... I know @VirMach eventually fix this.
    I spent way too much time on this. It's definitely a combination of things but in the end just essentially disabling ebtables got everything fixed... I'm speaking with SolusVM as I don't want to spend any more time trying to understand why that would cause all this. I have a few guesses in my head but I was completely surprised by this end result.
    It may of course have to do with how the network equipment configuration affects it as well, but wow.
    Thanked by (2)AlwaysSkint risturiz
    @gebilaowang said:
    I think so too, but there is indeed a problem with the aff link I mentioned, they didn't add any hints, which caused problems with subsequent activations, and now the situation is that all people who buy through aff should not have See the order number mentioned by @virmach. I believe you also found that not only me, but also some people in the comments on the LES forum can only issue their own invoices, because they did not record the order number.
    I don't think this should put the blame on the customer, we are victims too. Hopefully it will be handled properly in the end instead of "we don't care about information other than order number".
    If people outside the forum are not allowed to participate, I think it should at least be highlighted on the sales page, instead of adding an unsafe link to jump to, so that those of us don't pay attention to this prompt when buying. (Unsafe here means that the prompt page in the middle will be skipped.)
    Sorry I'm real busy and I'm only barely skimming over these messages here, I'm not going to provide any response really right now outside of I recommend anyone in a situation where they did not follow the offer rules for whatever reason tries their best not to detract from the offer rules any further by constantly bringing it up or messaging me everywhere, or making tickets, or spamming other invoice ID information.
    And I recommend they be very very very patient as it means they probably extended their activation time by days to weeks, and lost any guarantee of it being activated. But also don't freak out, we're not going to intentionally screw anyone over.
    It will just have to be done at the end of everything else when I have time to correct them.
    @hzz said:
    Invoice #1416230 please activate it, thank you
    @hzz said:
    View Ticket #912762
    So basically the exact opposite of this guy.
    @cybertech said:
    @VirMach Managed to kick my VM on TYOC040 offline by trying to boot Netboot.xyz ISO. Unable to boot/power on / reinstall.
    2560mb plan.
    do I make a ticket to get it booted?
    I don't think I've ever seen that happen, DM me your IP and I'll check the logs real quick but you shouldn't just lose your controls from that.
    Do you have one of these links so I can see what you mean? And how do you know what you are buying from the merchant if you skipped the page on the merchant's website verifying the specifications, etc? Not necessarily you specifically, you as in any person who follows the link.
    Thanked by (1)AlwaysSkint
  • edited April 2022
    So what do you think about this.I did buy the product you also marked on the invoice.
    yes very odd because few days back i did exact same thing, worked perfectly fine and successfully installed Debian 11 via netboot.
    DM sent.
  • So what do you think about this.I did buy the product you also marked on the invoice.
    Congratulations? I'm sure you'll be very happy with it? What are you looking for here?
    I have not made any aff links in any VPS service provider myself, but I know that the VPS service provider will give them some extra benefits (such as rebates) when purchasing through aff, that's all.
  • skorousskorous OG
    edited April 2022
    He's asking for an example aff link like you posted earlier. Pull one from hostloc to show him?
    EDIT: typo
  • edited April 2022
    EDIT: typo
    I didn't understand the last paragraph you said. . . Pull one from hostloc to show him?
    The modification date of this link is March 13, and the direct link will also skip the prompt and make the payment smoothly.
    https://p3terx.com/archives/cheap-vps-virmach-tokyo.html
    edited April 2022
    you joking right, why are you demanding Virmach to be responsible for a chinese website as though it was him who made that page?
    i can make a webpage too with my aff link and say free coffee for one year with each VPS purchase
    you are so funny!
    be serious now, who paid you to make jokes here?
    you are so funny!
    I'm just a novice, I just understood what this means. That is to say, all products purchased by aff are not responsible. Anyway, I did not write any configuration.
    Please understand, I didn't quite understand the principle of aff until he said so.
    That is, I bought something on his official website that no one knew what it was in the end.
    edited April 2022
    you are WRONG
    you bought something through an affman link
    the affman did not know what it was
    YOU do not know what it was
    YOU just follow affman words
    Virmach of course knows what they are selling.
    So novice, can you now understand? your problem is now with affman, can you go and punish affman now?
    beat affman with a whip or something
    bad, bad affman
    you are so funny!
    There is no need to create a Chinese website, if needed, it can be written clearly in Chinese on the order page. Or put a hyperlink on the order page and point to a page with special instructions in Chinese.
    Personal suggestion does not need a Chinese website.
    I don't remember this happened when I was posting buses. 🚍
    Just saying.
    LES • AboutDonateRulesSupport
  • @VirMach
    Hello, I still can't get my vps fixed, can't re-install the system, can't reach the vps by ssh, VNC only shows that the vps gets into rescue mode. Really need your help here.
    Please help me re-install the system, thank you!
    Ticket: #551307
  • @VirMach
    I purchased it through the link in this post and I did not see any order number during the purchase process, the email I received showed this message
    This is a payment receipt for Invoice 1416897 sent on 04/11/2022
    Ryzen Special 768 - HelplessBack-VM (04/11/2022 - 04/10/2024) $30.00 USD
    Selection Location: Tokyo, JP - Koto Ward, Tokyo -
    Operating System: Debian 11 (64Bit) Minimal
  • edited April 2022
    @cybertech said:
    you are WRONG
    bad, bad affman
    So I just hope @virmach closes these affman accounts when he's done with his business and doesn't offer them any rebates they get during the LES exclusive event. For example, the owner of this connection.
  • View Ticket #867190
    Order #561230
    Invoice #1416287
    Thank you
  • Hi there, I've just placed the order #2009489040,
    Pls activate it as u see fit, thank u for ur effort! @VirMach
  • edited April 2022
    Apart from the pathetic "u", this is the way it should be done.
    Read the rules, folks!
    Thanked by (1)kisser
  • edited April 2022
    @chenlil said: I purchased it through the link in this post and I did not see any order number during the purchase process, the email I received showed this message
    Someone wasn't paying attention? The instructions distinctly say to note it down from screen; you will NOT get an email with it.
    If I can't read/translate the ToS of a German provider, then I don't purchase. The same applies for any other language that is used on websites. It's a very simple principle to follow. If you don't understand, then don't buy.
    [Edit] Just spotted a typo - I hate that!
  • @Mason , @mikho
    Sorry guys, the flag still ain't working properly - noted when trying to flag the poster that needs a blog of his own. Guess who?
    Thanked by (1)Falzo
  • @AlwaysSkint said:
    Someone wasn't paying attention? The instructions distinctly say to note it down from screen; you will NOT get and email with it.
    Yes, people should learn to read. But there may be legit excuses for not taking order ID down. Remember the DDoS attack on Virmach site? IMHO, showing that ID only once is asking for trouble
