Please recommend a vps to me
I get 40 doller form paypal so i want to use this to buy a vps
  • virmach JP. It's rare to see this kind of price in non US, non EU location.
    let me see
  • @MCTGyt said:
    let me see
    it is too expensive! justhost is better then it
    u hav 40 doller
    then u say virmach too expensive
    then what u wan
  • @MCTGyt said:
    @MCTGyt said:
    let me see
    Did you checked this https://lowendspirit.com/discussion/4013/virmach-ryzen-nvme-30-2yr-768mb-40-2yr-1-5gb-50-2yr-2-5gb-70-2yr-4gb-les/ ?
  • @cybertech said:
    u hav 40 doller
    then what u wan
    no it is hkd not usd
    @MCTGyt said:
    @cybertech said:
    u hav 40 doller
    then what u wan
    Thanked by (1)Brueggus
  • Thanked by (1)Ganonk
  • @cybertech said:
    @MCTGyt said:
    @cybertech said:
    u hav 40 doller
    then what u wan
  • good but it is natvps so.... no :)
  • edited April 2022
    @MCTGyt said: justhost is better then it
    Than!
    Unless you are missing a comma, then it makes sense, as in Justhost is the better option.
    @cybertech said: then what u wan
    You're getting worse by the week!
    Thanked by (2)Falzo _MS_
  • lgsinlgsin OG
    edited April 2022
    Options are rather limited for 5 USD. Other than buying a month of VPS from the big companies e.g. digital ocean, linode , vultr, your best shot would be NAT vps.
    There are a few providers offering NAT vps on this forum. The plans that fit your budget are more likely to be out of stock so you'll have to try your luck.
    But natvps have not 80port
    my English is trying
    I think I need to setup a frp server :)
  • PacificRack is what you’re looking for
  • You need port 80, I guess you want to build a website.
    If you want to build a website, then finding a suitable web hosting provider will be a better choice.
    It's not realistic if you want quality service at such a low price.
    Thanked by (1)tetech
  • vyasvyas OGRetired
    edited April 2022
    @cybertech said:
    @MCTGyt said:
    @cybertech said:
    u hav 40 doller
    then what u wan
    Better than having 40 Zimbabwe doller
    you need to set up a server made of this? https://en.wikipedia.org/wiki/Fibre-reinforced_plastic
    Assuming you want to setup HTTP server, there are still ways to setup one with NAT vps, for example http proxy provided by the VPS provider, or cloudflare. As for FTP server, you can use non-standard port for IPv4 or standard port through IPv6.
  • @vyas said:
    @cybertech said:
    @MCTGyt said:
    @cybertech said:
    u hav 40 doller
    then what u wan
    I assume it means reverse proxy.
    Are you looking for monthly or yearly? You'll need to really dig to find a yearly at that price. Gullo maybe
    XR Developer | https://redironlabs.com
  • NeoonNeoon OG
    edited April 2022
    You don't want to use justhost.
    Plus, because of the embargo, you likely can't even pay them.
  • @MCTGyt said:
    @cybertech said:
    @MCTGyt said:
    @cybertech said:
    u hav 40 doller
    then what u wan
  • Check mzunguhosting.ml, they have very friendly CP offers.
    CP == cheap prices
    JustHost was always completely unusable even when you could pay them. Don't understand how that isn't common knowledge by now.
    I probably still have rubles credit with them from the time I decided to learn the hard way for myself. Hope I don't get sanctions.
    Can u tough me how to use cloudflare proxy
  • ... and the word is "you".
    You can google search and see a bunch of tutorials…
    你可以Google自己睇下啦
    https://techsch.com/tutorials/host-website-ipv6-nat-cloudflare-dns
    Thanked by (1)lgsin
    i know
    你可以Google自己睇下啦
    i'll try this
