Grep magic
I have this wonder in my logs:
FROM='Mr. Void <[email protected]>'|||ENV_FROM='<[email protected]>'
And this is my parser:
grep -oP "(?<=FROM=\').*?(?=\')"
It does work by bringing me both FROM and ENV_FROM. This is bad. I want EXACT match. Is it possible with lookbehind and lookahead?
  • MasonMason AdministratorOG
    @legendary said: This is bad. I want EXACT match.
    Is the "FROM" that you're after always at the start of a new line? If so, just change it to:
    grep -oP "(?<=^FROM=\').*?(?=\')"
    and it won't pick up the "ENV_FROM".
    Thanked by (2)Falzo legendary
  • Does: grep -oP "(?<=\bFROM=\').*?(?=\')" solve it for you? (I added \b before FROM to signify word boundary and it worked as I think how you'd like it to work - i.e only match FROM and not ENV_FROM).
    Here's a sample test case from me:
    (the first one is with a capital - not what you want, and the second one is with a lower case - I think what you want).
    echo "foo FROM='from_address' bar ENV_FROM='env_from_address' junk suffix\nFROM='Mr. Void <[email protected]>'|||ENV_FROM='<[email protected]>'\nfoo ENV_FROM='hello_how_are_you' bar FROM='howdy' baz" | grep -oP "(?<=\BFROM=\').*?(?=\')"
    gives me:
    env_from_address
    <[email protected]>
    hello_how_are_you
    And what I think you want is:
    echo "foo FROM='from_address' bar ENV_FROM='env_from_address' junk suffix\nFROM='Mr. Void <[email protected]>'|||ENV_FROM='<[email protected]>'\nfoo ENV_FROM='hello_how_are_you' bar FROM='howdy' baz" | grep -oP "(?<=\bFROM=\').*?(?=\')"
    gives me:
    from_address
    howdy
    Thanked by (3)Mason Falzo legendary
    gives me:
    env_from_address
    <[email protected]>
    hello_how_are_you
    gives me:
    from_address
    howdy
    Yes, \b did the trick. Thank you for your time and effort. Greatly appreciated.
