Looking to try any Shared Hosting/Reseller with Plesk WordPress Toolkit
Hey there,
looking to try (not necessarily buy) a shared hosting/reseller that has the Plesk WordPress Toolkit to give it a spin.
Can't say I'll become a (long term) customer but if you have some spare resources for a week or two (if necessary give me a quote), that'd be great
Specs: Enough to install WordPress (obviously) and just try out some things. Basically no expectations/requirements here.
Let me know if you have smth for me
Cheers,
Ympker
I happen to have a Cpanel Account with something called WordPress toolkit. Not the same I guess?
I haven't used Plesk WP Toolkit before (hence the OP), so, unfortunately, I can't say whether the cPanel WP Toolkit has the same features as the Plesk one. There is definitely also a cPanel toolkit: https://cpanel.net/wp-toolkit/
Our high performance plans have WP Toolkit + Plesk: https://cynderhost.com/store/high-performance-hosting
I think we've got a 50% discount code lying around somewhere....
Already found something, but thanks!
Hi,
You may try cheap Shared starter plan at us, https://servzen.com/shared-hosting.html
For WordPress, We are powered by DirectAdmin with Softaculous auto installer.
for reseller plans, https://servzen.com/reseller-hosting.html
Thanks
Servzen.com | Premium Hosting Provider!
Fast, secure and affordable plans | VPS Hosting | Shared Hosting.
Sooo... does your shared hosting plans have the Plesk WordPress Toolkit like the OP is asking for? Couldn't any information about it on your site.
Ahh, I just read the "looking to try any shared/reseller" only ...
My mistake.
Thanks, I was thinking the same. Anyway, like mentioned in my post before, I've found a solution for the OP now, so this thread can (technically) be closed
