3 Node Wireguard VPN
I'd like to setup 3 Wireguard VPN servers that share the same configation (port number, clients, etc, etc.)
For load balancing I'll use basic DNS (1 record, 3 ip addresses) - I know this has no heartbeat, etc.
For setup I'll just use @Nyr awesome script.
For syncing I'm thinking simple rsync would work just fine.
What's the best way to reload the wireguard config when I add new clients, etc? No downtime would be cool. I simple crontab that reloads it every so often would work as well.
Any thoughts? What am I missing?
In case it needs clarification, the script will deal with this on the master server (using a different and more complex approach, but does not matter).
For the slaves: cron + rsync + the one liner provided by @ralf is enough. No need to check if there are changes in advance, you can run
wg syncconf
every time as it will only act when changes are required.OpenVPN installer | WireGuard installer
