Seems to be from Alwyzon, I get similar performance. Seems like they're using some sort of NVMe or ZFS cache which is most likely why the disk benchmarks show some insane performance but if you try to put any sustained load the speeds drop
They use RAID6 meaning that there isn't any write speed gain, and it's pretty impossible for a single HDD to achieve 3 GB/s
Exactly, there is a small cache that transparently keeps a copy of the most recently used data blocks.
This approach keeps the most frequent read and write access away from the actual hard drives, and thus saves the capacity for when it's unavoidable. However, as Advin mentioned, you won't see these speeds if you try to access "cold" files like a large backup that's no longer in the cache. In the end, it's still HDDs after all. And, no, that's not ZFS, but a Dell PERC H740P controller handling it.
That's because he had a smaller plan that didn't had 4 vCores.
Those specs look quite familiar. Am I right?
— Michael
VPS reviews and benchmarks |
I see.
Multicore:
4 core ~ 4000
3 core ~ 2300
Singlecore:
Your : 1187
Mine: 767
— Michael
Provider?
Virmach
Ryzen upgraded
$12.95/year
RPI 3A+ 512MB RAM
orderlink?
impossible
why?
probably a flash sale
Hetzner AX41-NVMe Helsinki, fresh server with Debian 11.
Talistech.com — ICT Consultancy and NVMe web hosting solutions.
Time4vps - KVM Linux 2
Migrate from NY Buffalo to AMS Ryzen. Virmach NL AMS 1x2GBx25SSD Ryzen
Migrate from NY Buffalo to AMS Ryzen. Virmach NL AMS 2x0.5GBx5SSD 2xIP Ryzen
Guys better reinstall after migration ever if it work ok. Migrate from NY Buffalo to AMS Ryzen. Virmach NL AMS 1x2GBx25SSD Ryzen
Hetzner AX41-NVMe Nuremberg, equipped with two 512GB Samsung PM9A1 (soft RAID-0)
Terrahost AMS
mikrovps $6.34
Upcoming LXC VPS Lineup CLOUD VPS S
nice stats, when these will be live?
Which location? Will docker work?
MaxKVM Dallas with EPYC 7702P - $32.11/yr
These will be live within 1 week.
Initially planned locations are Germany & Singapore.
I will test docker tomorrow & let you know in PM.
CloudExpress 1 spec 1x1x20 SSD
https://webhorizon.net
Oneprovider Xeon L3426
# Yet-Another-Bench-Script #
# v2022-05-06 #
Oneprovider I3-540
# v2022-05-06 #
