Post some YABS bench here
1606163656699
    @Neoon said:
    Well, from 4068 down to 2324 on 4 Cores, is quite a hit
    That's because he had a smaller plan that didn't had 4 vCores.
    @LetMeBeSad said:
    HDD disk.
    Those specs look quite familiar. Am I right? :)
    — Michael
  • vyasvyas OGRetired
    edited May 2022
    @LetMeBeSad said:
    HDD disk.
    Uptime     : 20 days, 9 hours, 3 minutes
    Processor  : Intel(R) Xeon(R) Silver 4210 CPU @ 2.20GHz
    CPU cores  : 2 @ 2194.842 MHz
    VM-x/AMD-V : ❌ Disabled
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 984.3 GiB
    Kernel     : 5.17.9-xanmod1
    Read       | 137.16 MB/s  (34.2k) | 1.70 GB/s    (26.5k)
    Write      | 137.52 MB/s  (34.3k) | 1.71 GB/s    (26.7k)
    Total      | 274.69 MB/s  (68.6k) | 3.41 GB/s    (53.3k)
    Read       | 4.15 GB/s     (8.1k) | 3.16 GB/s     (3.0k)
    Write      | 4.37 GB/s     (8.5k) | 3.37 GB/s     (3.2k)
    Total      | 8.52 GB/s    (16.6k) | 6.53 GB/s     (6.3k)
    Clouvider       | London, UK (10G)          | 2.40 Gbits/sec  | 2.36 Gbits/sec
    Online.net      | Paris, FR (10G)           | 2.48 Gbits/sec  | 2.35 Gbits/sec
    Hybula          | The Netherlands (40G)     | 2.48 Gbits/sec  | 2.38 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 1.86 Gbits/sec  | 1.68 Gbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 1.72 Gbits/sec  | 2.00 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 590 Mbits/sec   | 255 Mbits/sec
    Clouvider       | London, UK (10G)          | 2.41 Gbits/sec  | 2.32 Gbits/sec
    Online.net      | Paris, FR (10G)           | 2.47 Gbits/sec  | 2.30 Gbits/sec
    Hybula          | The Netherlands (40G)     | 2.48 Gbits/sec  | 2.33 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 1.93 Gbits/sec  | 1.78 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 1.14 Gbits/sec  | 1000 Mbits/sec
    Geekbench 4 Benchmark Test:
    Single Core     | 3225
    Multi Core      | 6072
    Full Test       | https://browser.geekbench.com/v4/cpu/16557720
    Geekbench 5 Benchmark Test:
    Single Core     | 729
    Multi Core      | 1406
    Full Test       | https://browser.geekbench.com/v5/cpu/15080971
    I see.
    Multicore:
    4 core ~ 4000
    3 core ~ 2300
    Singlecore:
    Your : 1187
    Mine: 767
    Uptime     : 0 days, 0 hours, 3 minutes
    CPU cores  : 4 @ 3393.624 MHz
    RAM        : 7.8 GiB
    Swap       : 0.0 KiB
    Disk       : 159.9 GiB
    Read       | 618.54 MB/s (154.6k) | 3.61 GB/s    (56.5k)
    Write      | 620.17 MB/s (155.0k) | 3.63 GB/s    (56.8k)
    Total      | 1.23 GB/s   (309.6k) | 7.25 GB/s   (113.3k)
    Read       | 4.02 GB/s     (7.8k) | 3.90 GB/s     (3.8k)
    Write      | 4.24 GB/s     (8.2k) | 4.16 GB/s     (4.0k)
    Total      | 8.27 GB/s    (16.1k) | 8.06 GB/s     (7.8k)
    Clouvider       | London, UK (10G)          | 3.57 Gbits/sec  | 8.06 Gbits/sec
    Online.net      | Paris, FR (10G)           | 7.72 Gbits/sec  | 6.00 Gbits/sec
    Hybula          | The Netherlands (40G)     | 8.68 Gbits/sec  | 9.46 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 2.51 Gbits/sec  | 1.49 Gbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | busy            | busy
    Clouvider       | Los Angeles, CA, US (10G) | 1.35 Gbits/sec  | 1.54 Gbits/sec
    Single Core     | 6935
    Multi Core      | 22270
    Full Test       | https://browser.geekbench.com/v4/cpu/16557860
    Single Core     | 1635
    Multi Core      | 5465
    Full Test       | https://browser.geekbench.com/v5/cpu/15085485
    Thanked by (1)cybertech
  • AdvinAdvin Hosting Provider
    edited May 2022
    @vyas said:
    @LetMeBeSad said:
    HDD disk.
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 984.3 GiB
    Single Core     | 3225
    Multi Core      | 6072
    Single Core     | 729
    Multi Core      | 1406
    Seems to be from Alwyzon, I get similar performance. Seems like they're using some sort of NVMe or ZFS cache which is most likely why the disk benchmarks show some insane performance but if you try to put any sustained load the speeds drop :)
    They use RAID6 meaning that there isn't any write speed gain, and it's pretty impossible for a single HDD to achieve 3 GB/s :)
    Thanked by (2)vyas alwyzon
    edited May 2022
    Exactly, there is a small cache that transparently keeps a copy of the most recently used data blocks.
    This approach keeps the most frequent read and write access away from the actual hard drives, and thus saves the capacity for when it's unavoidable. However, as Advin mentioned, you won't see these speeds if you try to access "cold" files like a large backup that's no longer in the cache. In the end, it's still HDDs after all. And, no, that's not ZFS, but a Dell PERC H740P controller handling it.
    — Michael
    Thanked by (1)_MS_
    AES-NI : ✔ Enabled
    RAM : 7.8 GiB
    Swap : 0.0 KiB
    Disk : 159.9 GiB
    Test | Value
    Single Core | 6935
    Multi Core | 22270
    Test | Value
    Single Core | 1635
    Multi Core | 5465
    Provider?
    Virmach
    Ryzen upgraded
    $12.95/year
    #                     v2022-05-06                    #
    Tue 24 May 2022 03:41:55 AM EDT
    Processor  : AMD Ryzen 9 3900X 12-Core Processor
    CPU cores  : 3 @ 3799.996 MHz
    RAM        : 3.0 GiB
    Swap       : 256.0 MiB
    Disk       : 34.1 GiB
    Kernel     : 5.17.0-2-amd64
    Read       | 455.10 MB/s (113.7k) | 4.36 GB/s    (68.2k)
    Write      | 456.30 MB/s (114.0k) | 4.38 GB/s    (68.5k)
    Total      | 911.40 MB/s (227.8k) | 8.75 GB/s   (136.8k)
    Read       | 5.87 GB/s    (11.4k) | 4.74 GB/s     (4.6k)
    Write      | 6.18 GB/s    (12.0k) | 5.05 GB/s     (4.9k)
    Total      | 12.05 GB/s   (23.5k) | 9.79 GB/s     (9.5k)
    Clouvider       | London, UK (10G)          | 642 Mbits/sec   | 493 Mbits/sec
    Online.net      | Paris, FR (10G)           | busy            | busy
    Hybula          | The Netherlands (40G)     | 621 Mbits/sec   | 575 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 894 Mbits/sec   | 487 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 941 Mbits/sec   | 941 Mbits/sec
    Single Core     | 5571
    Multi Core      | 13714
    Full Test       | https://browser.geekbench.com/v4/cpu/16558155
    Single Core     | 1221
    Multi Core      | 3398
    Full Test       | https://browser.geekbench.com/v5/cpu/15092252
    Thanked by (1)szymonp
  • RPI 3A+ 512MB RAM
    Tue 24 May 12:59:31 CEST 2022
    Processor  : Cortex-A53
    CPU cores  : 4 @ 1400.0000 MHz
    AES-NI     : ❌ Disabled
    RAM        : 419.5 MiB
    Swap       : 100.0 MiB
    Disk       : 28.6 GiB
    Kernel     : 5.15.32-v8+
    Read       | 1.29 MB/s      (322) | 4.39 MB/s       (68)
    Write      | 1.32 MB/s      (331) | 4.66 MB/s       (72)
    Total      | 2.61 MB/s      (653) | 9.05 MB/s      (140)
    Read       | 4.55 MB/s        (8) | 4.68 MB/s        (4)
    Write      | 5.13 MB/s       (10) | 5.09 MB/s        (4)
    Total      | 9.68 MB/s       (18) | 9.77 MB/s        (8)
    Clouvider       | London, UK (10G)          | 20.7 Mbits/sec  | 28.4 Mbits/sec
    Online.net      | Paris, FR (10G)           | 44.3 Mbits/sec  | 56.1 Mbits/sec
    Hybula          | The Netherlands (40G)     | 44.0 Mbits/sec  | 55.1 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 34.8 Mbits/sec  | 23.8 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 41.2 Mbits/sec  | 12.6 Mbits/sec
  • @cybertech said:
    Virmach
    Ryzen upgraded
    $12.95/year
    orderlink?
    @lapua said:
    @cybertech said:
    Virmach
    Ryzen upgraded
    $12.95/year
    orderlink?
    impossible :)
  • @cybertech said:
    @lapua said:
    @cybertech said:
    Virmach
    Ryzen upgraded
    $12.95/year
    orderlink?
    impossible :)
    why?
  • @lapua said:
    @cybertech said:
    @lapua said:
    @cybertech said:
    Virmach
    Ryzen upgraded
    $12.95/year
    orderlink?
    impossible :)
    why?
    probably a flash sale
  • edited May 2022
    Hetzner AX41-NVMe Helsinki, fresh server with Debian 11.
    #                     v2022-05-06                    #
    Tue 24 May 2022 03:24:36 PM CEST
    Uptime     : 0 days, 1 hours, 4 minutes
    Processor  : AMD Ryzen 5 3600 6-Core Processor
    CPU cores  : 12 @ 2194.872 MHz
    RAM        : 62.8 GiB
    Swap       : 32.0 GiB
    Disk       : 436.7 GiB
    Kernel     : 5.10.0-9-amd64
    Read       | 604.44 MB/s (151.1k) | 628.50 MB/s   (9.8k)
    Write      | 606.03 MB/s (151.5k) | 631.80 MB/s   (9.8k)
    Total      | 1.21 GB/s   (302.6k) | 1.26 GB/s    (19.6k)
    Read       | 553.17 MB/s   (1.0k) | 539.92 MB/s    (527)
    Write      | 582.56 MB/s   (1.1k) | 575.88 MB/s    (562)
    Total      | 1.13 GB/s     (2.2k) | 1.11 GB/s     (1.0k)
    Clouvider       | London, UK (10G)          | 927 Mbits/sec   | 924 Mbits/sec
    Hybula          | The Netherlands (40G)     | 929 Mbits/sec   | 926 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 883 Mbits/sec   | 360 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 836 Mbits/sec   | 344 Mbits/sec
    Clouvider       | London, UK (10G)          | 905 Mbits/sec   | 861 Mbits/sec
    Hybula          | The Netherlands (40G)     | 911 Mbits/sec   | 905 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 856 Mbits/sec   | 255 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 809 Mbits/sec   | 201 Mbits/sec
    Single Core     | 1294
    Multi Core      | 7430
    Full Test       | https://browser.geekbench.com/v5/cpu/15097556
    Thanked by (2)cybertech ralf
    Talistech.com — ICT Consultancy and NVMe web hosting solutions.
  • Time4vps - KVM Linux 2
    #                     v2022-05-06                    #
    Wed May 25 00:21:16 EEST 2022
    Uptime     : 0 days, 0 hours, 18 minutes
    Processor  : Intel Xeon Processor (Skylake, IBRS)
    CPU cores  : 1 @ 2593.906 MHz
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 19.6 GiB
    Distro     : Ubuntu 20.04.4 LTS
    Kernel     : 5.4.0-113-generic
    Read       | 388.00 KB/s     (97) | 6.22 MB/s       (97)
    Write      | 411.00 KB/s    (102) | 6.58 MB/s      (102)
    Total      | 799.00 KB/s    (199) | 12.81 MB/s     (199)
    Read       | 24.39 MB/s      (47) | 23.87 MB/s      (23)
    Write      | 25.77 MB/s      (50) | 26.29 MB/s      (25)
    Total      | 50.16 MB/s      (97) | 50.17 MB/s      (48)
    Clouvider       | London, UK (10G)          | 96.4 Mbits/sec  | 95.3 Mbits/sec
    Online.net      | Paris, FR (10G)           | 96.3 Mbits/sec  | 95.2 Mbits/sec
    Hybula          | The Netherlands (40G)     | 96.5 Mbits/sec  | 95.4 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 93.8 Mbits/sec  | 92.8 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 90.5 Mbits/sec  | 90.8 Mbits/sec
    Clouvider       | London, UK (10G)          | 95.0 Mbits/sec  | 94.0 Mbits/sec
    Online.net      | Paris, FR (10G)           | 95.1 Mbits/sec  | 94.1 Mbits/sec
    Hybula          | The Netherlands (40G)     | 95.1 Mbits/sec  | 93.8 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 92.0 Mbits/sec  | 52.0 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 89.0 Mbits/sec  | 89.6 Mbits/sec
    Single Core     | 831
    Multi Core      | 836
    Full Test       | https://browser.geekbench.com/v5/cpu/15104214
  • ofitofit OG
    edited May 2022
    Migrate from NY Buffalo to AMS Ryzen. Virmach NL AMS 1x2GBx25SSD Ryzen
    #                     v2022-05-06                    #
    Срд 25 мая 2022 15:09:57 CEST
    Uptime     : 0 days, 0 hours, 10 minutes
    CPU cores  : 1 @ 3499.996 MHz
    AES-NI     : ❌ Disabled
    RAM        : 1.9 GiB
    Swap       : 256.0 MiB
    Disk       : 24.3 GiB
    Read       | 215.53 MB/s  (53.8k) | 355.84 MB/s   (5.5k)
    Write      | 216.10 MB/s  (54.0k) | 357.71 MB/s   (5.5k)
    Total      | 431.64 MB/s (107.9k) | 713.55 MB/s  (11.1k)
    Read       | 940.55 MB/s   (1.8k) | 1.04 GB/s     (1.0k)
    Write      | 990.52 MB/s   (1.9k) | 1.11 GB/s     (1.0k)
    Total      | 1.93 GB/s     (3.7k) | 2.16 GB/s     (2.1k)
    Clouvider       | London, UK (10G)          | 674 Mbits/sec   | 490 Mbits/sec
    Online.net      | Paris, FR (10G)           | busy            | 398 Mbits/sec
    Hybula          | The Netherlands (40G)     | 634 Mbits/sec   | 816 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 389 Mbits/sec   | 101 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 415 Mbits/sec   | 140 Mbits/sec
    Single Core     | 757
    Multi Core      | 828
    Full Test       | https://browser.geekbench.com/v5/cpu/15115320
    Migrate from NY Buffalo to AMS Ryzen. Virmach NL AMS 2x0.5GBx5SSD 2xIP Ryzen
    root@s14:~# curl -sL yabs.sh | bash
    #                     v2022-05-06                    #
    Срд 25 мая 2022 15:58:22 CEST
    Processor  : AMD EPYC-Rome Processor
    CPU cores  : 2 @ 3493.436 MHz
    RAM        : 462.9 MiB
    Swap       : 768.0 MiB
    Disk       : 4.6 GiB
    Kernel     : 5.10.0-8-amd64
    Read       | 203.61 MB/s  (50.9k) | 228.89 MB/s   (3.5k)
    Write      | 204.15 MB/s  (51.0k) | 230.10 MB/s   (3.5k)
    Total      | 407.76 MB/s (101.9k) | 458.99 MB/s   (7.1k)
    Read       | 487.21 MB/s    (951) | 574.46 MB/s    (560)
    Write      | 513.09 MB/s   (1.0k) | 612.71 MB/s    (598)
    Total      | 1.00 GB/s     (1.9k) | 1.18 GB/s     (1.1k)
    Clouvider       | London, UK (10G)          | 648 Mbits/sec   | 421 Mbits/sec
    Hybula          | The Netherlands (40G)     | 747 Mbits/sec   | 871 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 458 Mbits/sec   | 167 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 556 Mbits/sec   | 156 Mbits/sec
    Single Core     | 924
    Multi Core      | 1459
    Full Test       | https://browser.geekbench.com/v5/cpu/15116141
  • Guys better reinstall after migration ever if it work ok. Migrate from NY Buffalo to AMS Ryzen. Virmach NL AMS 1x2GBx25SSD Ryzen
    root@UprightTaut-VM:~# curl -sL yabs.sh | bash
    #                     v2022-05-06                    #
    Wed May 25 17:05:07 CEST 2022
    Uptime     : 0 days, 1 hours, 0 minutes
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 24.3 GiB
    Kernel     : 5.4.0-105-generic
    Read       | 249.92 MB/s  (62.4k) | 378.78 MB/s   (5.9k)
    Write      | 250.58 MB/s  (62.6k) | 380.77 MB/s   (5.9k)
    Total      | 500.51 MB/s (125.1k) | 759.56 MB/s  (11.8k)
    Read       | 971.41 MB/s   (1.8k) | 1.48 GB/s     (1.4k)
    Write      | 1.02 GB/s     (1.9k) | 1.58 GB/s     (1.5k)
    Total      | 1.99 GB/s     (3.8k) | 3.06 GB/s     (2.9k)
    Clouvider       | London, UK (10G)          | 631 Mbits/sec   | 427 Mbits/sec
    Online.net      | Paris, FR (10G)           | busy            | 454 Mbits/sec
    Hybula          | The Netherlands (40G)     | 574 Mbits/sec   | 801 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 233 Mbits/sec   | 98.8 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 323 Mbits/sec   | 128 Mbits/sec
    Single Core     | 899
    Multi Core      | 900
    Full Test       | https://browser.geekbench.com/v5/cpu/15117262
  • Hetzner AX41-NVMe Nuremberg, equipped with two 512GB Samsung PM9A1 (soft RAID-0)
    #                     v2022-05-06                    #
    Thu 26 May 2022 12:55:00 AM CST
    Uptime     : 0 days, 5 hours, 38 minutes
    CPU cores  : 12 @ 3600.000 MHz
    RAM        : 62.8 GiB
    Swap       : 0.0 KiB
    Disk       : 936.6 GiB
    Read       | 960.72 MB/s (240.1k) | 2.86 GB/s    (44.7k)
    Write      | 963.26 MB/s (240.8k) | 2.87 GB/s    (44.9k)
    Total      | 1.92 GB/s   (480.9k) | 5.73 GB/s    (89.6k)
    Read       | 3.83 GB/s     (7.4k) | 3.92 GB/s     (3.8k)
    Write      | 4.03 GB/s     (7.8k) | 4.18 GB/s     (4.0k)
    Total      | 7.86 GB/s    (15.3k) | 8.11 GB/s     (7.9k)
    Clouvider       | London, UK (10G)          | 930 Mbits/sec   | 935 Mbits/sec
    Online.net      | Paris, FR (10G)           | 936 Mbits/sec   | 938 Mbits/sec
    Hybula          | The Netherlands (40G)     | 936 Mbits/sec   | 938 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 889 Mbits/sec   | 455 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 837 Mbits/sec   | 296 Mbits/sec
    Clouvider       | London, UK (10G)          | 919 Mbits/sec   | 922 Mbits/sec
    Online.net      | Paris, FR (10G)           | busy            | 925 Mbits/sec
    Hybula          | The Netherlands (40G)     | 924 Mbits/sec   | 924 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 878 Mbits/sec   | 306 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 825 Mbits/sec   | 282 Mbits/sec
    Single Core     | 1327
    Multi Core      | 7838
    Full Test       | https://browser.geekbench.com/v5/cpu/15118937
  • Terrahost AMS
    #                     v2022-05-06                    #
    Wed May 25 21:07:52 CEST 2022
    Uptime     : 0 days, 0 hours, 6 minutes
    CPU cores  : 1 @ 3393.624 MHz
    RAM        : 1.9 GiB
    Swap       : 980.0 MiB
    Disk       : 38.1 GiB
    Kernel     : 5.10.0-14-amd64
    Read       | 323.90 MB/s  (80.9k) | 2.64 GB/s    (41.2k)
    Write      | 324.76 MB/s  (81.1k) | 2.65 GB/s    (41.4k)
    Total      | 648.66 MB/s (162.1k) | 5.29 GB/s    (82.7k)
    Read       | 4.18 GB/s     (8.1k) | 4.29 GB/s     (4.1k)
    Write      | 4.40 GB/s     (8.6k) | 4.58 GB/s     (4.4k)
    Total      | 8.59 GB/s    (16.7k) | 8.88 GB/s     (8.6k)
    Clouvider       | London, UK (10G)          | 3.42 Gbits/sec  | 7.75 Gbits/sec
    Online.net      | Paris, FR (10G)           | 8.14 Gbits/sec  | 5.05 Gbits/sec
    Hybula          | The Netherlands (40G)     | 8.81 Gbits/sec  | 9.34 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 1.78 Gbits/sec  | 1.59 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 1.27 Gbits/sec  | 1.39 Gbits/sec
    Clouvider       | London, UK (10G)          | 8.69 Gbits/sec  | 232 Mbits/sec
    Online.net      | Paris, FR (10G)           | 7.70 Gbits/sec  | 7.87 Gbits/sec
    Hybula          | The Netherlands (40G)     | 8.72 Gbits/sec  | 9.26 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 2.23 Gbits/sec  | 2.51 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 1.09 Gbits/sec  | 1.39 Gbits/sec
    Single Core     | 1690
    Multi Core      | 1698
    Full Test       | https://browser.geekbench.com/v5/cpu/15120721
    mikrovps $6.34
    #                     v2022-05-06                    #
    Thu May 26 01:29:17 UTC 2022
    Uptime     : 3 days, 21 hours, 9 minutes
    Processor  : Intel(R) Xeon(R) CPU E5-1660 v3 @ 3.00GHz
    CPU cores  : 4 @ 2762.864 MHz
    RAM        : 8.0 GiB
    Swap       : 0.0 KiB
    Disk       : 146.6 GiB
    Distro     : CentOS Linux 7 (Core)
    Kernel     : 5.4.162-1-pve
    Read       | 819.40 MB/s (204.8k) | 711.44 MB/s  (11.1k)
    Write      | 821.56 MB/s (205.3k) | 715.18 MB/s  (11.1k)
    Total      | 1.64 GB/s   (410.2k) | 1.42 GB/s    (22.2k)
    Read       | 1.59 GB/s     (3.1k) | 686.36 MB/s    (670)
    Write      | 1.68 GB/s     (3.2k) | 732.07 MB/s    (714)
    Total      | 3.27 GB/s     (6.3k) | 1.41 GB/s     (1.3k)
    Clouvider       | London, UK (10G)          | 492 Mbits/sec   | 937 Mbits/sec
    Hybula          | The Netherlands (40G)     | 492 Mbits/sec   | 936 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 438 Mbits/sec   | 894 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 35.0 Mbits/sec  | 829 Mbits/sec
    Clouvider       | London, UK (10G)          | 485 Mbits/sec   | 923 Mbits/sec
    Online.net      | Paris, FR (10G)           | 487 Mbits/sec   | 927 Mbits/sec
    Hybula          | The Netherlands (40G)     | 485 Mbits/sec   | 924 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 444 Mbits/sec   | 881 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 27.6 Mbits/sec  | 695 Mbits/sec
    Single Core     | 783
    Multi Core      | 1466
    Full Test       | https://browser.geekbench.com/v5/cpu/15124257
  • Upcoming LXC VPS Lineup CLOUD VPS S
    #                     v2022-05-06                    #
    Thu 26 May 2022 06:53:08 AM UTC
    Uptime     : 0 days, 0 hours, 4 minutes
    Processor  : Intel(R) Xeon(R) E-2386G CPU @ 3.50GHz
    CPU cores  : 2 @ 4846.173 MHz
    RAM        : 8.0 GiB
    Swap       : 1024.0 MiB
    Disk       : 49.0 GiB
    Kernel     : 5.4.174-2-pve
    Read       | 1.62 GB/s   (406.8k) | 3.50 GB/s    (54.8k)
    Write      | 1.63 GB/s   (407.9k) | 3.52 GB/s    (55.1k)
    Total      | 3.25 GB/s   (814.7k) | 7.03 GB/s   (109.9k)
    Read       | 3.72 GB/s     (7.2k) | 3.67 GB/s     (3.5k)
    Write      | 3.92 GB/s     (7.6k) | 3.91 GB/s     (3.8k)
    Total      | 7.65 GB/s    (14.9k) | 7.58 GB/s     (7.4k)
    Clouvider       | London, UK (10G)          | 966 Mbits/sec   | 7.86 Gbits/sec
    Online.net      | Paris, FR (10G)           | 968 Mbits/sec   | 8.16 Gbits/sec
    Hybula          | The Netherlands (40G)     | 968 Mbits/sec   | 9.36 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 865 Mbits/sec   | 2.16 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 838 Mbits/sec   | 1.17 Gbits/sec
    Single Core     | 1684
    Multi Core      | 3082
    Full Test       | https://browser.geekbench.com/v5/cpu/15127406
    > #              Yet-Another-Bench-Script              #
    > #                     v2022-05-06                    #
    > # https://github.com/masonr/yet-another-bench-script #
    > Basic System Information:
    > AES-NI     : ✔ Enabled
    > VM-x/AMD-V : ✔ Enabled
    > RAM        : 8.0 GiB
    > Swap       : 1024.0 MiB
    > Disk       : 49.0 GiB
    > fio Disk Speed Tests (Mixed R/W 50/50):
    > iperf3 Network Speed Tests (IPv4):
    > Test            | Value
    > Single Core     | 1684
    > Multi Core      | 3082
    nice stats, when these will be live?
    Which location? Will docker work?
    MaxKVM Dallas with EPYC 7702P - $32.11/yr
    #                     v2022-05-06                    #
    Thu May 26 13:39:25 CDT 2022
    Uptime     : 0 days, 2 hours, 55 minutes
    Processor  : AMD EPYC 7702P 64-Core Processor
    CPU cores  : 2 @ 1999.999 MHz
    RAM        : 3.9 GiB
    Swap       : 1024.0 MiB
    Disk       : 72.7 GiB
    Kernel     : 3.10.0-1160.66.1.el7.x86_64
    Read       | 248.15 MB/s  (62.0k) | 1.52 GB/s    (23.7k)
    Write      | 248.80 MB/s  (62.2k) | 1.52 GB/s    (23.8k)
    Total      | 496.95 MB/s (124.2k) | 3.05 GB/s    (47.6k)
    Read       | 1.75 GB/s     (3.4k) | 1.86 GB/s     (1.8k)
    Write      | 1.84 GB/s     (3.6k) | 1.99 GB/s     (1.9k)
    Total      | 3.60 GB/s     (7.0k) | 3.85 GB/s     (3.7k)
    Clouvider       | London, UK (10G)          | 250 Mbits/sec   | 1.70 Gbits/sec
    Online.net      | Paris, FR (10G)           | 1.65 Gbits/sec  | 1.37 Gbits/sec
    Hybula          | The Netherlands (40G)     | 1.22 Gbits/sec  | 1.28 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 2.23 Gbits/sec  | 4.80 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 3.26 Gbits/sec  | 5.88 Gbits/sec
    Single Core     | 4401
    Multi Core      | 7870
    Full Test       | https://browser.geekbench.com/v4/cpu/16559593
    Single Core     | 942
    Multi Core      | 1879
    Full Test       | https://browser.geekbench.com/v5/cpu/15138555
    LES • AboutDonateRulesSupport
    > > #                     v2022-05-06                    #
    > > AES-NI     : ✔ Enabled
    > > RAM        : 8.0 GiB
    > > Swap       : 1024.0 MiB
    > > Disk       : 49.0 GiB
    > > Test            | Value
    > > Single Core     | 1684
    > > Multi Core      | 3082
    These will be live within 1 week.
    Initially planned locations are Germany & Singapore.
    I will test docker tomorrow & let you know in PM.
    Thanked by (2)FrankZ dosai
  • CloudExpress 1 spec 1x1x20 SSD
    root@localhost:~# curl -sL yabs.sh | bash
    #                     v2022-05-06                    #
    Няд 29 мая 2022 17:20:57 +03
    Uptime     : 0 days, 0 hours, 19 minutes
    Processor  : Intel Xeon E3-12xx v2 (Ivy Bridge)
    CPU cores  : 1 @ 2299.998 MHz
    RAM        : 976.4 MiB
    Swap       : 0.0 KiB
    Disk       : 19.8 GiB
    Read       | 8.00 MB/s     (2.0k) | 65.51 MB/s    (1.0k)
    Write      | 8.04 MB/s     (2.0k) | 65.96 MB/s    (1.0k)
    Total      | 16.04 MB/s    (4.0k) | 131.47 MB/s   (2.0k)
    Read       | 64.13 MB/s     (125) | 63.59 MB/s      (62)
    Write      | 67.34 MB/s     (131) | 67.90 MB/s      (66)
    Total      | 131.48 MB/s    (256) | 131.49 MB/s    (128)
    Clouvider       | London, UK (10G)          | 197 Mbits/sec   | 194 Mbits/sec
    Online.net      | Paris, FR (10G)           | 192 Mbits/sec   | 185 Mbits/sec
    Hybula          | The Netherlands (40G)     | 196 Mbits/sec   | 194 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 175 Mbits/sec   | 188 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 131 Mbits/sec   | 173 Mbits/sec
    Single Core     | 564
    Multi Core      | 558
    Full Test       | https://browser.geekbench.com/v5/cpu/15190427
    edited May 2022
    #                     v2022-05-06                    #
    Mon 30 May 2022 07:01:30 PM UTC
    Uptime     : 0 days, 0 hours, 38 minutes
    Processor  : Intel(R) Xeon(R) E-2274G CPU @ 4.00GHz
    CPU cores  : 2 @ 4294.264 MHz
    RAM        : 8.0 GiB
    Swap       : 1024.0 MiB
    Disk       : 97.9 GiB
    Read       | 928.36 MB/s (232.0k) | 2.79 GB/s    (43.6k)
    Write      | 930.81 MB/s (232.7k) | 2.80 GB/s    (43.8k)
    Total      | 1.85 GB/s   (464.7k) | 5.59 GB/s    (87.4k)
    Read       | 885.89 MB/s   (1.7k) | 2.84 GB/s     (2.7k)
    Write      | 932.96 MB/s   (1.8k) | 3.03 GB/s     (2.9k)
    Total      | 1.81 GB/s     (3.5k) | 5.87 GB/s     (5.7k)
    Clouvider       | London, UK (10G)          | 484 Mbits/sec   | 289 Mbits/sec
    Online.net      | Paris, FR (10G)           | 485 Mbits/sec   | 7.77 Gbits/sec
    Hybula          | The Netherlands (40G)     | 485 Mbits/sec   | 8.45 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 449 Mbits/sec   | 2.15 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 437 Mbits/sec   | 1.24 Gbits/sec
    Single Core     | 1172
    Multi Core      | 2216
    Full Test       | https://browser.geekbench.com/v5/cpu/15211187
  • Oneprovider Xeon L3426
    # v2022-05-06 #
    Tue May 31 01:35:09 CEST 2022
    Uptime     : 0 days, 0 hours, 13 minutes
    Processor  : Intel(R) Xeon(R) CPU           L3426  @ 1.87GHz
    CPU cores  : 8 @ 1386.236 MHz
    AES-NI     : ❌ Disabled
    RAM        : 15.7 GiB
    Swap       : 4.1 GiB
    Disk       : 3.6 TiB
    Distro     : Ubuntu 18.04.6 LTS
    Kernel     : 4.15.0-180-generic
    Read       | 1.19 MB/s      (297) | 16.66 MB/s     (260)
    Write      | 1.22 MB/s      (305) | 17.15 MB/s     (267)
    Total      | 2.41 MB/s      (602) | 33.81 MB/s     (527)
    Read       | 48.45 MB/s      (94) | 49.62 MB/s      (48)
    Write      | 51.24 MB/s     (100) | 52.70 MB/s      (51)
    Total      | 99.69 MB/s     (194) | 102.33 MB/s     (99)
    Clouvider       | London, UK (10G)          | 727 Mbits/sec   | 853 Mbits/sec
    Online.net      | Paris, FR (10G)           | 818 Mbits/sec   | 857 Mbits/sec
    Hybula          | The Netherlands (40G)     | 654 Mbits/sec   | 864 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 346 Mbits/sec   | 677 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 24.1 Mbits/sec  | 333 Mbits/sec
    Single Core     | 349
    Multi Core      | 1326
    Full Test       | https://browser.geekbench.com/v5/cpu/15213821
    Oneprovider I3-540
    # v2022-05-06 #
    Tue May 31 01:54:32 CEST 2022
    Uptime     : 25 days, 2 hours, 42 minutes
    Processor  : Intel(R) Core(TM) i3 CPU         540  @ 3.07GHz
    CPU cores  : 4 @ 1581.516 MHz
    AES-NI     : ❌ Disabled
    RAM        : 3.8 GiB
    Swap       : 4.1 GiB
    Disk       : 1.8 TiB
    Kernel     : 4.15.0-176-generic
    Read       | 742.00 KB/s    (185) | 10.89 MB/s     (170)
    Write      | 778.00 KB/s    (194) | 11.38 MB/s     (177)
    Total      | 1.52 MB/s      (379) | 22.28 MB/s     (347)
    Read       | 28.94 MB/s      (56) | 30.79 MB/s      (30)
    Write      | 30.94 MB/s      (60) | 33.43 MB/s      (32)
    Total      | 59.88 MB/s     (116) | 64.23 MB/s      (62)
    Clouvider       | London, UK (10G)          | 610 Mbits/sec   | 807 Mbits/sec
    Online.net      | Paris, FR (10G)           | 610 Mbits/sec   | 779 Mbits/sec
    Hybula          | The Netherlands (40G)     | 629 Mbits/sec   | 838 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 512 Mbits/sec   | 676 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 156 Mbits/sec   | 422 Mbits/sec
    Single Core     | 475
    Multi Core      | 1029
    Full Test       | https://browser.geekbench.com/v5/cpu/15213937
    Thanked by (2)cybertech chimichurri
