It appears that people are really saturating the network for whatever reason. The geekbench looks pretty alright considering it’s a 4-core CPU so that’s not an issue, just the network.
Perhaps it’s something to do with LXC? Unlikely but I guess @Abdullah is the only one who knows
Sadly not, still less than 50. Nothing alarming just noted while running yabs 😅
https://www.speedtest.net/result/c/5528a38d-566f-449e-a957-b0cfd0d0b6b5
Got mine, work perfectly! Let see how it's when the node is full
I get 70 uplaod but only a third of your download
https://www.speedtest.net/result/13268960045
Thanks for sharing!
full already now. maybe 1-2 more will provision to this.
https://webhorizon.net
From my node (I have the early offer):
Is this recurring?
Can these be stacked? (kinda need double of the annual spec)
It is recurring
IPv4 & CPU cannot be stacked. Should work for you ?
or can order multiple single ones.
enabled BBR congestion control on host
you can also get this, by rebooting VM.
verify
sysctl net.ipv4.tcp_congestion_control
If it outputs bbr congrats you're set.
congrats your screwed now.
j/k haha hho ha ( @yoursunny laughing sounds )
Did I break something?
i was just kidding didn't get a message like "your all set" when adjusting kernel parameters...
btw, you know these thing don't take effect until sysctl -a , or reboot i think.
I got this as output,
net.ipv4.tcp_congestion_control = cubic
finally, speed
https://www.speedtest.net/result/13269312195
now connection is very unstable, rdp keeps on freezing, ssh keeps on kicking me and/or becoming unresponsive
Same here. I did a reinstall, guess I'll wait for a few days for things to settle.
patience is key i suppose. i trust @Abdullah will get everything going nicely like usually
ok it got better now it seems
https://www.speedtest.net/result/13269420768
Me too. I'm in no hurry.
@dosai all should be good now. did you get bbr working after reinstall ?
there was someone doing port scans with zmap causing packet drops for others. abuser is suspended now.
Alright, good to see that you took care of that quickly
Recived bbr after reinstall. Cheers man.
Network is good now
Thanks for the offer, works well! But how to enable TUN? I can't find it in the solusvm panel with my other VMs.
Try this possibly:
https://help.skysilk.com/support/solutions/articles/9000136471--intermediate-how-to-enable-tun-tap-on-linux-vps-with-skysilk
Unfortunately that doesn't work, I found https://my.webhorizon.in/plugin/support_manager/knowledgebase/view/7/how-to-enable-tun-tap-on-my-vps/ though but as I mentioned I don't have this VPS in my (NAT) control panel.
Just reboot the VPS once after installation, TUN device is enabled automatically on these LXC VMs,
