It appears that people are really saturating the network for whatever reason. The geekbench looks pretty alright considering it’s a 4-core CPU so that’s not an issue, just the network.
Perhaps it’s something to do with LXC? Unlikely but I guess @Abdullah is the only one who knows
Sadly not, still less than 50. Nothing alarming just noted while running yabs 😅
https://www.speedtest.net/result/c/5528a38d-566f-449e-a957-b0cfd0d0b6b5
Got mine, work perfectly! Let see how it's when the node is full
I get 70 uplaod but only a third of your download
https://www.speedtest.net/result/13268960045
Thanks for sharing!
full already now. maybe 1-2 more will provision to this.
https://webhorizon.net
From my node (I have the early offer):
Is this recurring?
Can these be stacked? (kinda need double of the annual spec)
It is recurring
IPv4 & CPU cannot be stacked. Should work for you ?
or can order multiple single ones.
enabled BBR congestion control on host
you can also get this, by rebooting VM.
verify
sysctl net.ipv4.tcp_congestion_control
If it outputs bbr congrats you're set.
congrats your screwed now.
j/k haha hho ha ( @yoursunny laughing sounds )
Did I break something?
i was just kidding
didn't get a message like "your all set" when adjusting kernel parameters...
btw, you know these thing don't take effect until sysctl -a , or reboot i think.
I got this as output,
net.ipv4.tcp_congestion_control = cubic
finally, speed
https://www.speedtest.net/result/13269312195
now connection is very unstable, rdp keeps on freezing, ssh keeps on kicking me and/or becoming unresponsive
Same here. I did a reinstall, guess I'll wait for a few days for things to settle.
patience is key i suppose. i trust @Abdullah will get everything going nicely like usually
ok it got better now it seems
https://www.speedtest.net/result/13269420768
Me too. I'm in no hurry.
@dosai all should be good now. did you get bbr working after reinstall ?
there was someone doing port scans with zmap
causing packet drops for others. abuser is suspended now.
Alright, good to see that you took care of that quickly![:D :D](https://staging.lowendspirit.com/plugins/emojiextender/emoji/twitter/grin.png)
Recived bbr after reinstall. Cheers man.
Network is good now![:+1: :+1:](https://staging.lowendspirit.com/plugins/emojiextender/emoji/twitter/+1.png)
Thanks for the offer, works well! But how to enable TUN? I can't find it in the solusvm panel with my other VMs.
Try this possibly:
https://help.skysilk.com/support/solutions/articles/9000136471--intermediate-how-to-enable-tun-tap-on-linux-vps-with-skysilk
Unfortunately that doesn't work, I found https://my.webhorizon.in/plugin/support_manager/knowledgebase/view/7/how-to-enable-tun-tap-on-my-vps/ though but as I mentioned I don't have this VPS in my (NAT) control panel.
Just reboot the VPS once after installation, TUN device is enabled automatically on these LXC VMs,
