Weekend deal - VPS LXC 8GB RAM Unlimited 10Gbps - $4/mo. - WebHorizon
2
  • @Abdullah said:
    @dosai did it improve then?
    Sadly not, still less than 50. Nothing alarming just noted while running yabs 😅
    https://www.speedtest.net/result/c/5528a38d-566f-449e-a957-b0cfd0d0b6b5
  • Got mine, work perfectly! Let see how it's when the node is full
  • edited June 2022
    I get 70 uplaod but only a third of your download
    https://www.speedtest.net/result/13268960045
    Thanks for sharing!
    full already now. maybe 1-2 more will provision to this.
    Thanked by (1)sonic
    edited June 2022
    From my node (I have the early offer):
    Clouvider       | London, UK (10G)          | 72.3 Mbits/sec  | 5.23 Gbits/sec
    Online.net      | Paris, FR (10G)           | 90.5 Mbits/sec  | 3.62 Gbits/sec
    Hybula          | The Netherlands (40G)     | 101 Mbits/sec   | 7.95 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 12.7 Mbits/sec  | 1.76 Gbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | busy            | busy
    Clouvider       | Los Angeles, CA, US (10G) | 10.2 Mbits/sec  | 1.14 Gbits/sec
    It appears that people are really saturating the network for whatever reason. The geekbench looks pretty alright considering it’s a 4-core CPU so that’s not an issue, just the network.
    Perhaps it’s something to do with LXC? Unlikely but I guess @Abdullah is the only one who knows
  • Is this recurring?
    Can these be stacked? (kinda need double of the annual spec)
    @teamacc said:
    Is this recurring?
    It is recurring
    Thanked by (1)teamacc
    edited June 2022
    @bruh21 said:
    @teamacc said:
    Is this recurring?
    It is recurring
    IPv4 & CPU cannot be stacked. Should work for you ?
    or can order multiple single ones.
    enabled BBR congestion control on host
    Clouvider       | London, UK (10G)          | 472 Mbits/sec   | 5.71 Gbits/sec
    Online.net      | Paris, FR (10G)           | 474 Mbits/sec   | 4.54 Gbits/sec
    Hybula          | The Netherlands (40G)     | 461 Mbits/sec   | 8.11 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 391 Mbits/sec   | 1.38 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 269 Mbits/sec   | 1.07 Gbits/sec
    you can also get this, by rebooting VM.
    verify sysctl net.ipv4.tcp_congestion_control
    If it outputs bbr congrats you're set.
    Thanked by (1)bruh21
  • ehabehab Content Writer
    edited June 2022
    congrats your screwed now.
    j/k haha hho ha ( @yoursunny laughing sounds )
    Did I break something?
    i was just kidding :) didn't get a message like "your all set" when adjusting kernel parameters...
    btw, you know these thing don't take effect until sysctl -a , or reboot i think.
    Thanked by (1)Abdullah
    > iperf3 Network Speed Tests (IPv4):
    I got this as output,
    net.ipv4.tcp_congestion_control = cubic
  • now connection is very unstable, rdp keeps on freezing, ssh keeps on kicking me and/or becoming unresponsive
    Same here. I did a reinstall, guess I'll wait for a few days for things to settle.
    patience is key i suppose. i trust @Abdullah will get everything going nicely like usually
    ok it got better now it seems
    Me too. I'm in no hurry.
    @dosai all should be good now. did you get bbr working after reinstall ?
    there was someone doing port scans with zmap :/ causing packet drops for others. abuser is suspended now.
    Alright, good to see that you took care of that quickly :D
    Recived bbr after reinstall. Cheers man.
  • Basic System Information:
    Uptime     : 0 days, 0 hours, 38 minutes
    Processor  : Intel(R) Xeon(R) E-2274G CPU @ 4.00GHz
    CPU cores  : 2 @ 4000.000 MHz
    AES-NI     : ��� Enabled
    VM-x/AMD-V : ��� Enabled
    RAM        : 7.8 GiB
    Swap       : 512.0 MiB
    Disk       : 97.9 GiB
    Distro     : Ubuntu 20.04.4 LTS
    Kernel     : 5.15.35-1-pve
    Read       | 617.81 MB/s (154.4k) | 1.81 GB/s    (28.3k)
    Write      | 619.44 MB/s (154.8k) | 1.82 GB/s    (28.5k)
    Total      | 1.23 GB/s   (309.3k) | 3.64 GB/s    (56.9k)
    Read       | 2.31 GB/s     (4.5k) | 2.40 GB/s     (2.3k)
    Write      | 2.43 GB/s     (4.7k) | 2.56 GB/s     (2.5k)
    Total      | 4.75 GB/s     (9.2k) | 4.96 GB/s     (4.8k)
    Clouvider       | London, UK (10G)          | 483 Mbits/sec   | 8.47 Gbits/sec
    Online.net      | Paris, FR (10G)           | 483 Mbits/sec   | 7.38 Gbits/sec
    Hybula          | The Netherlands (40G)     | 483 Mbits/sec   | 8.46 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 446 Mbits/sec   | 2.07 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 439 Mbits/sec   | 1.24 Gbits/sec
    Geekbench 5 Benchmark Test:
    Single Core     | 1070
    Multi Core      | 2001
    Full Test       | https://browser.geekbench.com/v5/cpu/15416405
  • edited June 2022
    Network is good now :+1:
  • Thanks for the offer, works well! But how to enable TUN? I can't find it in the solusvm panel with my other VMs.
    Try this possibly:
    https://help.skysilk.com/support/solutions/articles/9000136471--intermediate-how-to-enable-tun-tap-on-linux-vps-with-skysilk
  • @szymonp said:
    Try this possibly:
    Unfortunately that doesn't work, I found https://my.webhorizon.in/plugin/support_manager/knowledgebase/view/7/how-to-enable-tun-tap-on-my-vps/ though but as I mentioned I don't have this VPS in my (NAT) control panel.
    edited June 2022
    Just reboot the VPS once after installation, TUN device is enabled automatically on these LXC VMs,
    Thanked by (1)lowba75
