Ympker's New Flat - Suggestions/Advice
2»
    edited June 2022
    @chris said:
    Eat whatever and enjoy your GF! The rest is irrelevant in the footnotes of a long marriage 😝
    Best of luck in your new home
    The KISS principle, I see :D
    Thanks for the good wishes, mate!
  • You know, me and my wife lived in abject poverty looking back! Some of the happiest times though!
    Sat laughing our heads off on a free sofa - we still do the same on overpriced ones.... but with less responsibility 😁
    Serious advice, save up for the perfect item - never settle for something not quite right, we've wasted loads that way! Cable every room and still get mesh WiFi!
    edited June 2022
    I can imagine :D Even with little money, life can be enjoyed. As students we certainly can't spend that much either :P
    Sounds like you guys had a great and memorable time back then! Those kinda memories are the best :P
    Noted! Better to get the better one straight away (even if saving longer for it) than buying cheap and replace.
    Thanks for the advice!
    Thanked by (1)chris
  • Living with a woman often means you face a choice between being right and being happy. Choose wisely.
    Everything else falls into the correct place over time. :)
    Thanked by (2)bikegremlin Ympker
    Wondering whether I should just buy a 20meter LAN cable to connect the second pc in bedroom to the internet. Will I notice a big difference in between a 20m Cat 5e and Cat 8 cable?
  • "Always buy the best, never settle" - Me to anyone, anytime I get the opportunity 😛
    Haha alright :D I understand the Cat 8 shields a bit better against outward interference than the Cat 5e, so for a long distance of 20 meters that's probably better :)
    @Falzo do you know anything about those fancy cables?
    no you won't.
    Thanked by (2)Ympker bikegremlin
    @Falzo said:
    no you won't.
    Thanks. Then I'll go for the cheaper one :)
  • Future proof your entire life 😛
  • I'd got for cat6 if they have it on hand...likely to be similar price as 5e
    7 & 8 tends to be a lot stiffer than 5/6 so is a pain to pull in
    Good advice. Thanks!
