Boss please help me, now there are several problems with vps:
Migration order not completed Ticket#461588
vps offline for two months
The vps is about to expire but the renewal bill has not yet been paid.
Node Name:SJCZ004
Hostname:DVww-13 @VirMach
@VirMach said: We finally set up Chicago Hivelocity. Since Chicago servers already got moved, a lot of people will be going there from former Buffalo location but it'll also be available on Ryzen button.
You likely have lots of other stuff on your mind right now, but will we get the Ryzen migration button enabled for services that have been auto-migrated to a (more or less) arbitrary location eventually?
This was already supposed to be enabled but there's so many segmentation of packages and locations that there's obviously some cases where it's not going through. I'm going to see if we can change the filter today to make it more of a free-for-all.
In case some examples help, I don't see the button for my services with IDs 132295, 616449, 564859 and 52388.
@netrix said: on my side, even paid migration was not automated (#596130 since 26/07/2022).
me too. @VirMach ach hasn't been around in a long time.
Migrations to Tokyo end up having a lot of issues and they're vastly more popular than other requests. I don't know if yours is a Tokyo request but if it is then please understand there are hundreds of requests we're trying to catch up with in Tokyo.
My server in Chicago CHI026 is down and I can't get into the background
It keeps showing Operation Timed Out After 90001 Milliseconds With 0 Bytes Received
You moved the server that was working fine in Buffalo to Chicago without my permission, and now it doesn't work at all. What do you want to do? I have nothing to say. Please fix the problem now, thanks
SJC2005 appears to be offline (was ok a few days ago, idk when it went out), and other SJC server (SJC2003?) has been out for quite a while. Client alert area says SJC2008 is having trouble. Altogether it sounds like the whole SJ site is not doing too well.
I opened a ticket #462238
uh oh OGF users are coming
I just hope that virmach's service can be more stable. It was very stable before, but since it was launched in Japan, it has not been normal, and it has been tossing and turning again and again.
@hzz said:
Yes, it started to be unstable. Then the VPS went offline for 8 days, and no one replied to the work order. It is estimated that the pace of running is required.
I have a cpanel service through the VPShared brand. It is still surviving. Seems weird they would spend the effort to migrate it a few weeks ago to the new node but then give up, given how expensive servers are atm...
Interesting, mine has been unreachable for months, supposedly because CC had permanently nullrouted the node IP. I ended up moving my site from it to a VPS. Was yours in Buffalo? It would be nice if I could get access to mine, even if it's not publiclyback on the air.
Looks like TYOC031 is being hammered quite hard right now, hope the anti-abuse script finds the culprit soon.
Node Name:SJCZ004
Hostname:DVww-13
@VirMach
Try vda1 instead of vda.
Thanks but there is no
/dev/vda1
(I presume) because the partition table on/dev/vda
is boned.fdisk -l
lists no partitions for/dev/vda
either.TYO-C040 offline since 2d 17hr ago, and i can't reinstall it
benchmark score of the vps I've ever had
same here, storage vps where working and are offline now =(
opened a ticket but not answer yet
AlwaysGrammarly
CHI2Z028 went down almost 4 hours ago now. It had been solid after the migration to it from a crapcrossing server until now.
that fixed my server, thanks. stupid
C'mon now. If you're going to be like that you have to at least use, "Bite my shiny metal ass".
LOL
haha you are right.
i am kidding dont worry guys.
@VirMach
My VM on TYOC035 has been down for 24hrs+. Seems the whole node is down.
@VirMach long time no see
My new wallpaper
VPS reviews and benchmarks |
Have you read the opening post?
so virmach is deadpool?
That's what you got out of the last 60+ pages?
Yep. They spent probably hundreds of thousands on new Ryzen servers just so they can deadpool a month later.
/s (obviously, but with OGF users starting to come here I feel like that disclaimer is needed for some of them)
One thinks that one should return to the OGF.
Woooooorrrrkkkk Ooorrrdeeeeeeeer
Problems at the machine room.
