BuyVM have usually some new stocks in the begin of each months. You could also use ServerHunter or similar to get notifications when they have availability
There is some stock atm for LU 1GB and 2GB BuyVM slice, however slabs are usually at the start of the month so you can sign at https://buyvmstock.com for stock notify.
This is going to be hard to find. Maybe try Kimsufi
[email protected] | www.ivlad.net
I currently have 2 vps with inception hosting, needing an upgrade on the storage though and there's never any storage vps in stock.
Was looking at buy vm with a slab in Luxemburg too but same story with the slabs. Never in stock
