Considered moving some stuff over, but CF still has a couple things I need/want. e.g. Ability to rate limit say an API endpoint by IP & run cloudworkers w/ KV
@havoc said: Considered moving some stuff over, but CF still has a couple things I need/want. e.g. Ability to rate limit say an API endpoint by IP & run cloudworkers w/ KV
Bunny has that, you can set up request limits in their panel.
Just noticed they added SSD storage too...interesting for small sites that have a couple megs of data so doesn't really matter what the cost per gig is
oh that's cool. Just found it...maybe that's new cause I don't recall it. Thanks!
@AaronSS said:
Wow... In just 4 days I've had 117,116 Queries. Do they change for all Queries or just ones that reply back?
I'd hope all queries get sent replies
I do wonder whether there is some sort of DDoS mitigation in place. i.e. if someone sends a couple billion requests your way
Hi, I'm testing Bunny Geo DNS (Smart Queries) and I'm lean to believe that unresolved queries count, like records without IPv6.
What are your thoughts?
I always wanted to use Bunny (and that's also the reason why i always bought credit whenever i had the occasion, even though I never generated enough traffic for it to be touched).
So far so good. I’m not seeing much difference from cloudflare for my use case.
That works around 878k per 30 days, based on the pricing I wouldn't worry too much: Standard Queries (First 20 million) FREE
That's exactly what I use it for!
Do they provide full ipv6 support?
No
YES, FINALLY!
