@atomi said:
Wait, patience is a virtue. There are plenty of VPSs on that node so maybe some other user will confirm issue or maybe it will be unlocked
I locked it off to avoid a hundred re-installs from happening while we made sure it's stabilized/recreated the ones that already did do that. I've unlocked it now.
Amsterdam network maintenance emails going out. It's going to be a short notice but I think we've worked out all the kinks. I'd give a longer notice, it's just not feasible with how scheduling works. If it's too far out then the time will be less precise and I want to make sure we're able to work with the same person that already did FFM to avoid repeat issues.
@cybertech said:
IPv6 not working in Frankfurt anybody?
Wait, Frankfurt have native IPv6 already?
I use with both NL and DE Route48 IPv6 tunnel, so in case there's native IPv6 already I didn't even realize...
@atomi said:
I have IPv6 available servers in FFME002 and FFME007 but not in FFME006
Do you have IPv6 address listed in your SolusVM (or client area VPS management) or it just appeared in the interface after the network reconfiguration.
Listed in client area, Solus and VPS but still nothing
Actually FFME002 has /64 and FFME007 /48 but it doesnt make any different since both are pretty much dead
I forgot about inodes and I don't even have half of files I wanted there.
Fuck, time to reinstall, I guess... but maybe different server so I will get bigger disk?
Hey VirMach how much for upgrade from SSD1G (0.45$ per year) to NVMe2G?
RYZE.AMS-D025.VMS seems have been offline for some time after the maintenace E-mail.
Getting Operation Timed Out After 90001 Milliseconds With 0 Bytes Received prompts in WHMCS and SolusVM says Status Unknown.
The RYZE.AMS-D001.VMS or AMSD030X temp testing node is doing fine on the other hand.
ps. I hope I can get that NVMe2G prize sooner if you are not too busy. @VirMach
mine has been doing 2.5K on 1m tops. Debian 11 + 5.10
Oh no how will you ever be able to do anything with just 2.5K IOPS on 1M (aka 2.5GB/s)
That's not even enough to impress a girl at a party!
(edit) What node is that on? Let me shut down every other VM on the same disk as you so you can get a nice number
Impressing girls at parties is all I use my VirMach VMs for! My usecase has been destroyed
i didn't mean any /S but since we're already on it:
FFME003. I wanna see you do it!
@VirMach PHXZ004 network become terrible again ,what happend ?
Hello! I can't access my VPS, it shows "The node is currently locked." What's going on here? Thanks.
It's TYO036. @VirMach
it surely doesnt help you to spam same messages again and again
So what should I do?
Oh, got it. Thank you for your advice.
Thanks, sir.
Is the paid migration function working properly now? it keeps spinning.
How can i login the control panel without the client area?
Find e-mail you got when ordering server ("Your cloud service is almost ready (IP)") and go to section "Advanced Control Panel" there.
Seems to be working here, but I am not using IPv6, it's just enabled because reconfigure networks
not working here, cannot ping gateway and reconfiguring network doesnt help
FFME007 doesn't seems IPv6 ready or is it? I don't see IPv6 under client area, SolusVM network or VPS interface (apart from my IPv6 tunnel setup).
ipv6 works on FFME001. Just had to reconfig network. A nice /48
Use XFS.
How it's gonna help me now?
RYZE.AMS-D025.VMSseems have been offline for some time after the maintenace E-mail.Getting
Operation Timed Out After 90001 Milliseconds With 0 Bytes Receivedprompts in WHMCS and SolusVM saysStatus Unknown.The
RYZE.AMS-D001.VMSorAMSD030Xtemp testing node is doing fine on the other hand.ps. I hope I can get that NVMe2G prize sooner if you are not too busy. @VirMach
(edit: node name)
Agent Data Warning
Monitor: WR Replication AMS025
Agent hasn't sent any data in the past: 100 minutes
Can confirm.
