The bad new is that you are still down when the node is up.
Yes, I knew that already after the troubleshooter debug data.
Do you have any understanding of the cause ?
No, the service was activated 24 hours after the payment, it appears offline since its activations.
Did it happen after doing a particular thing or did it not come back up after the node issue on or about Dec 14th ?
The service was ordered on December 24, activated on December 25. only thing I've tried was power it on, via Virmach user panel and minutes later, via Solusvm control panel. None of both seems to work.
Do you think that we here might have a helpful suggestion to get you going if you gave us more information ?
Yes and I believe the recreation of the VM will fix the issue, instantly.
Of course if you feel it is better to wait on the VirMach support ticket I completely understand.
Don't mind to share VM information.
Thanks for getting back to me with all the info. You seem to have run thru the checklist under the yellow "Issue New Service" button and it still does not even show online. I expect you are correct and Virmach will need to fix or recreate your VM on his end. I have one that I recently purchased on PHXZ001 with similar issues. I personally have not made a ticket for this as I expect that it will be taken care of automatically as VirMach make his rounds checking that all the VMs created properly. However I am not in a rush for provisioning, and you are, so I completely understand why you ticketed regarding this issue.
@WHo said:
Please tell me why TYOC035 can offline with disk issue twice in 3 month?
Very high "you fixed my computer and now every time it breaks it's because of the thing you did 3 months ago" vibes. Not everything is related in the same exact way. This time it's even worse.
But if it is hardware broken for the disk,maybe you better consider to change not fix.
@FrankZ said: Thanks for getting back to me with all the info. You seem to have run thru the checklist under the yellow "Issue New Service" button and it still does not even show online. I expect you are correct and Virmach will need to fix or recreate your VM on his end. I have one that I recently purchased on PHXZ001 with similar issues. I personally have not made a ticket for this as I expect that it will be taken care of automatically as VirMach make his rounds checking that all the VMs created properly. However I am not in a rush for provisioning, and you are, so I completely understand why you ticketed regarding this issue.
Thanks for sharing that information. I'll wait and hope for the service come online during this month. When the issue is finally fixed, I'll post about it.
thanks, will keep an eye on this.
this is my 'stuff' in 2core4gb ram so i figure i could place this in a vps
but well, probably will trying inside a vm first so i don't get f<3<3ked by the tos yadayada
Just an FYI the customized VPS show the price for one year on the customizer, but that is actually the price for two years. When you click thru to the next page it should show the price Biennially (every two years.)
When I had a VM with VirMach it idled for a whole year. Reinstalled a few times, had to open a ticket to get those windows reinstall done (part of the instructions they gave at the time).
Never used for production, specially due to the fair share policy. I cant run stuff with fear of having something suspended. I prefer to just pay dedicated servers or VM with dedicated cores that I can blast 24/7.
But I bet it would be a good VPN or jump box. Would use for stuff like that for sure. Or if dedicated cores were available as addons in the special offers.
Yes and No. Those are old HDD limits, VirMach said they need to update those and they have much higher limits for kill-scripts now... but it's still there so can be used against you! ;')
However I don't recall anyone coming here (or there) complaining about "I was unjustifiably suspended" except few abusers that (like the one in this thread earlier that went nuts and because he did not use whole bandwidth he thinks it was okey )
When it reach 7T of 8T , I stop this service, but still suspended by virmach (...)
i see, I'll check again if it's really cheaper in biennially term
anyone running billion dollar business with virmach here? I'm sure there are one or two. praise the $7
delivered within an hour of purchase, however, in some cases, it may take longer.
LIMITED OFFER
$18.68 /yr
KVM – 1 GIGABIT
4340MB DDR4 RAM
3 vCORE (RYZEN 3.4GHz+)
25GB SSD (NVMe)
2560GB MONTHLY DATA
SEATTLE, WA LOCATION
1 DEDICATED IPv4
Has anyone noticed that the initial disks images for Virmach VM's contain a pre-existing image?
LIMITED OFFER
$7.95 /yr
KVM – 1 GIGABIT
868MB DDR4 RAM
1 vCORE (RYZEN 3.4GHz+)
35GB SSD (NVMe)
3584GB MONTHLY DATA
NYC METRO, NJ LOCATION
1 DEDICATED IPv4
Can you show some screen shots of what you are saying in #3.
Just for example
$22.01 /yr
KVM – 1 GIGABIT
3929MB DDR4 RAM
55GB SSD (NVMe)
5632GB MONTHLY DATA
CHICAGO, IL LOCATION
2 DEDICATED IPv4
This was nice
how'd you use these 'limited offer' ?
I'm looking for 4GB ram vps, but to see 2 dedicated ipv4, why?
You can buy limtied offer from bottom link
https://virmach.com/flash-sale/
VirMach Black Friday Flash Sale Tracker No aff
Nan, go to customization, choose the spec ya want
https://virmach.com/black-friday-cyber-monday/
Whaaaaaaaaaaaaaaaagh 2expensive4me on 4gig ram
$6.29 /yr
KVM – 1 GIGABIT
985MB DDR4 RAM
20GB SSD (NVMe)
2048GB MONTHLY DATA
1 DEDICATED IPv4
6.29!
Low spec no brainer, one of the best so far
MJJ rating 145% worthy
LIMITED OFFER
$7.77 /yr
KVM – 1 GIGABIT
768MB DDR4 RAM
35GB SSD (NVMe)
3584GB MONTHLY DATA
AMSTERDAM, NL LOCATION
1 DEDICATED IPv4
No Brainer!
Europe is awake now
*Woke Woke Woke*
MJJ rating 117% worthy
Flash Sale have better formula :-)
Perfect time @VirBOT - it's not like it's 3-5 AM in Europe now
That AUP of VirMach:
"High I/O: Customer’s Service cannot average more than 80 IOPS within any two (2) hour period"
Is that a misprint?
He managed to use 7TB of bandwidth within 2 days while going nuts on disk and he thinks it's okey
https://lowendspirit.com/discussion/comment/120289/#Comment_120289
Do you have any experience one way or the other?
LIMITED OFFER
$18.68 /yr
KVM – 1 GIGABIT
4340MB DDR4 RAM
25GB SSD (NVMe)
2560GB MONTHLY DATA
1 DEDICATED IPv4
@Encoders
[[Screams Externally]]
I did transferred my VPS 4x4x100 from NL to DE. Working good. And network work good. Performance better than on NL.
I've got one! A baby monster, sort of. :P
IMPRESSIVE!
