Free i9-12900K Proxmox Accounts At Hetzner HEL1
Edit February 13, 2023: We hope to reinstall today with un-Proxmoxed Debian sid.
Bare metal traditional shell accounts and/or pretty much anything else Proxmox or Proxmox's underlying Debian can do.
Friendly greetings to all! 🌎🌍
root@ex100 ~ # free -h
Mem: 125Gi 1.2Gi 123Gi 47Mi 457Mi 123Gi
Swap: 6.0Gi 0B 6.0Gi
root@ex100 ~ # df -h .
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/vg0-root 3.4T 3.1G 3.2T 1% /
root@ex100 ~ # df -h /altroot
/dev/md2 98G 28K 93G 1% /altroot
root@ex100 ~ # cat /etc/debian_version
11.6
root@ex100 ~ # uptime
22:10:26 up 19:03, 2 users, load average: 0.00, 0.00, 0.00
root@ex100 ~ # lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
Address sizes: 46 bits physical, 48 bits virtual
CPU(s): 24
On-line CPU(s) list: 0-23
Thread(s) per core: 1
Core(s) per socket: 16
Socket(s): 1
NUMA node(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 151
Model name: 12th Gen Intel(R) Core(TM) i9-12900K
Stepping: 2
CPU MHz: 3200.000
CPU max MHz: 5200.0000
CPU min MHz: 800.0000
BogoMIPS: 6374.40
Virtualization: VT-x
L1d cache: 384 KiB
L1i cache: 256 KiB
L2 cache: 10 MiB
NUMA node0 CPU(s): 0-23
root@ex100 ~ #
Thanked by (1)ariq01
MetalVPS
@Not_Oles wow this is a beefy server. Can I request a proxmox account? I'd like to host coder.io and do some dev in python whilst having a remote accessible ide
Thanks
That is a big step up from darkstar
congrats!
coder.io seems to be squatted.
Maybe you could try ed.io? NXDOMAIN for ed.io.
MetalVPS
Will check ed.io
I think I misquoted the same.. it's https://github.com/coder/code-server
Self hosted VS code
Yeah, code-server seems to be the fully open source version of Microsoft's partly closed source vscode.
Presumably you already also know about the ed editor and about the fun history of ed editor jokes. The ed editor jokes are what make me think about the ed.io domain.
I saw your post about transferring your AX41. and your post about transferring your VPS because you have another dedicated server. These posts that I saw make it sound like you have adequate server resources. Are you just joking about installing and using code-server on my EX100?
MetalVPS
Yup, had moved client projects from VPS to a dedi earlier in 2022... Don't wanna host anything personal there; better to keep it separate.
I'd like to host/ test out the self-hosted VS code and the beefy CPU pulled me here.
Of course this is pure hobby/ learning for me so and getting my hands dirty on some Python coding... Maybe this could be something installed on the server and can be offered as an env for folks to learn coding?
What are your thoughts?
Sounds like a good idea! Let's see if we can get code-server installed! I had it on another machine awhile back. So maybe I can install it again. At this moment, the electrician is here and the power is off while he is working. Might take awhile to get the power back. I will let you know. Thanks!
MetalVPS
Hello, apologies for my absence. Electricians were here for a couple of days, rewiring, so no internet. Then I decided to try configuring IPv4 NAT and port forwarding for the VMs. NAT seems to be working because, from within the test container, curl to icanhazip.com gives me the expected main IPv4 of the server and the IPv6 of the container:
WAN ssh into the test container seems to be working fine over IPv6, but not with port forwarding over IPv4. I might post again about the IPv4 port forwarding, There also is a test KVM cooking.
@localhost On the vscode idea, might there might be at least three flavors: code from Microsoft, code-server from Hashicorp,](https://github.com/coder/code-server) and vscodium?
Hope everyone is enjoying a fun day! It's bright and sunny here! ☀
MetalVPS
I had test a lot of funny things on a server you provided before.
It is so convenient to test something on a server with good network speed and hight performance.
Can I request a new account on this server ?
Thanks!
Heyo kind person!
May I want an account too? I will mainly use it to collect high-frequency market data for mainly research purposes. If my research succeeds, I also am willing to provide some horse power like you
Also willing to setup some development environment for intel-optimized AI libraries to use it with the very same research.
LES is lucky to have you.
Cheers!
Hi @Not_Oles , can I have proxmox account too? I will host code-server as well for remote development purposes.
Thank you.
Hi @furkey!
Thanks for your message! From https://lowendspirit.com/discussion/comment/43205/#Comment_43205 where you said
it seems like you already have many resources.
Also, I am unfamiliar with your suggested uses, high-frequency market data research and Intel-optimized AI libraries.
Are you sure my server is a good fit for you?
Thanks again! Best wishes!
Tom
MetalVPS
@subenhon
Delighted to have you! Thanks for asking!
I grabbed your ssh key from the other server. Any chance you have a static IP (and maybe a backup static IP) from which access through the EX100's firewall can be allowed?
Tom
MetalVPS
Hi @jcolideles!
Yes, I am delighted to give you an account! Can you send me, please, your ed25519 ssh public key and a static IP (and maybe a static backup IP) from which access through the server firewall can be allowed? Can be IPv4 or IPv6 or one of each. Thanks!
Best wishes!
Tom
MetalVPS
I believe thr code-server looks promising as its stripped of all proprietary MS stuff...
Thanks!
I had send my IP via PM ,please check the inbox.
Hi guys! I see that I have messages in my inbox from @subenhon and from @jcolideles. It's getting late here, so I will tend to the accounts tomorrow. @localhost Got your preference for code-server. Do you also want to send me a static login IP and maybe a backup IP plus an ed25519 ssh public key, please? Best wishes! Tom
MetalVPS
@Not_Oles Hello again.
The post belongs to 2 years before, Turkey's economy was way better then
Right now USD/TRY parity has climbed from 8 to somewhere near 19, so I had to shut them down. Right now, the only server I have is from netcup. They are hard to beat at price/performance ratio. It was a joint effort by me and one of my friend, again due to the high exchange rate. However, I am to shut there down too because my friend decided not to continue anymore because, again, exchange rate. I was about to search for cheaper and affordable alternatives and saw your post so I gave it a shot.
3-core Epyc was more than sufficient for that data collection pipe. I haven't use it on 12900k but I heard that single core performance is better than those Epyc processors, so there is a good chance it will fit in. Other intel-optimized data science thing may not be necessary, but a nice to have. Since I got a Ryzen 5 3600 at home, those preprocessing part was somewhat slow, but certainly usable.
Bests!
@localhost Friendly reminder if you still are interested.
Containers seem to be up for @subenhon and @jcolideles. PM sent to each of you.
WAN access via IPv6 and IPv4 NAT seems to be working from within the containers. However, IPv4 port forwarding from WAN to the containers isn't working yet. So, for the time being, IPv6 is required to access containers via ssh.
@furkey Thanks for your message! Several of my friends have visited Türkiye. They have told me stories of many kindnesses extended to them, wonderful food, and beautiful scenery. Of course, I would like to repay the kindnesses extended to my friends. But, for this server, I want to be able to change the operating system from time to time and repeatedly and randomly break whatever OS is installed at the moment. For your financial project, don't you need a stable platform? Best wishes nonetheless!
MetalVPS
Apologies, missed the earlier tag. Will send across the ip/ key
Hey @Not_Oles
Kindnesses are the ones being done without expecting anything in return. Your kind words mean more than a server or anything else. Hope you can visit Turkiye too, and please don't forget to reach out to me if you do so. I would be more than happy to show you Turkish hospitality
Yeah, I need some kind of stable thing. Guess it was not meant to be for me. Thanks for giving a shot, thanks for the community service and thanks for being awesome!
Have a great one!
Good morning!
Having talked with the guys using the server, we hopefully will reinstall today with Debian sid. Thanks to Proxmox for being great! I might start a new thread once Debian is up.
Best!
Tom
MetalVPS
