1128129131133134156
  • Finally, all VPS are back!
    AMS
    LAX
    SEA
    above are up
    SJO seems down
  • jtkjtk
    edited April 2023
    @Jab said:
    @VirMach copy-paste from LET, I am to stupid to understand it, but maybe important :D
    That was me. In a nutshell, I suspect some of those who were reporting partial connectivity (e.g., through a VPN, but not from their home cable provider), were able to temporarily reach their systems, because their VPN provider accepted a /20 route from QuadraNet, while their cable provider did not. The reason for some providers not accepting the route was due to a missing, corresponding ROA (route object authorization) published into the RPKI.
    In a nutshell, the RPKI is to routing what DNSSEC is for DNS. A ROA is an attestation that a particular origin AS is authorized to announce a particular prefix. If a BGP announcement is made with an origin AS not in a corresponding ROA, many providers will drop the route, and this is known as enforcing ROV (route origin validation). There are now associated ROAs to authorize QuadraNet, among others, to originate prefixes in the /17. This was not the case yesterday.
    From what I can tell, Virmach has nothing to do with this process and it is probably all more-or-less automated by Alibaba. My guess is that was probably the last thing Alibaba had to update to restore full connectivity.
  • Patiently waiting to be able to set rDNS for new NL. ;)
    Thanked by (2)shallow titus
  • @AlwaysSkint said: Patiently waiting to be able to set rDNS for new NL.
    GLWRDNS
    Thanked by (1)AlwaysSkint
  • @Jab said: GLWRDNS
    It's gonna happen... this time.
  • edited April 2023
    Inorite? I'm getting tired of my friends seeing my vps' ip address in our private irc room. I have silly vanity domains that need to be put to use.
  • @shallow said: Inorite? I'm getting tired of my friends seeing my vps' ip address in our private irc room. I have silly vanity domains that need to be put to use.
    That's where IPv6 tunnel come handy :P
    Oh, and don't dare to join my channel just to say "Ciao a tutti" (in colours!) and then immediately leave. :s
  • edited April 2023
    Weekly check whether Virmach ran away.
    No yet, see yor chaps next week
  • This is one of the reasons why I check if Virmach has gone out of business once a day.
  • Hey @VirMach had a decent amount of sleep?
  • ehabehab Content Writer
    @Jab said:
    Hey @VirMach had a decent amount of sleep weed?
  • edited April 2023
    Weed, beers and hookers!
    Thanked by (1)ehab
  • Laxa032 is timeout right now
    I have 2 or 3 vps with extra IP's per vps and after the change have only main IP! did any get the extra IP's visible in the the cp?
    it's still time out.
    Operation Timed Out After 90001 Milliseconds With 0 Bytes Received
    Can't connect via ssh either.
    But it shows green on this page: https://statusbot.virm.ac/en/
    No one on the same node?
  • Oddly enough after reading most of the thread I had to go over and check them out. Tried to buy a hosting plan, well because reasons, and could not create an account or even buy the vps.
  • Should I actually contact support or should I just wait a couple months? This server is in Los Angeles; I've got one in Seattle that's still 'on hold' for IPv6, so not sure it's worth bothering support if they're not deploying IPv6 in LA yet.
  • TYOC031 is down.
    Yeah, just woke up.
    rDNS/PTR for Frankfurt, Amsterdam, and Tokyo should be done soon (available on SolusVM.)
    @fan said:
    TYOC031 is down.
    These got cleaned up. Not down, just overloading. Ran the newest patch for them yesterday, hopefully will prevent future overloading.
  • @VirMach said:
    Yeah, just woke up.
    Have you updated the IP Geo info?
  • JabJab
    edited April 2023
    @Fritz said: Have you updated the IP Geo info?
    Thanks for quoting my post, I love random notifications.
    Thanked by (3)AlwaysSkint skorous FrankZ
    @VirMach said:
    Yeah, just woke up.
    that's quite a long sleep
    @VirMach should we open tickets if the vps is missing IP's ? this was from the recent change.
    Yes.
  • @Fritz said: Yes.
    Spoiler
    It's been put in, now it's up to them (main few companies) to process it or however long it'll take.
    We're working on a solution, we've already flagged down how many IPs each plan should have and will use that to auto clean them up. But you can also use the missing IP button if it's there.
    Thanked by (1)ehab
    edited April 2023
    If it fails and you contact support make sure you make it more about the function not working rather than mentioning you want IPv6 or it will probably be closed/told to use button.
    That way we can see what's going on with that so you can make the request.
    But at this point the request button isn't really how people think it is, we're basically using it as a voting system to know which ones we should do first in bulk node by node.
    (edit) Actually don't even mention the button not working, you should definitely make a ticket for the virtual server missing error as that will cause other problems too.
