@Abdullah said: I'm guessing that is India location, (using a different approach there - Domain Forwarding) UDP ports need to be forwarded manually, by creating a ticket.
Yes. Raising a ticket now.
I have replied your ticket. On these NAT VPS, ports are assigned according to the internal IP. I hope that works
Any issues in network
VPS has gone down 4 times in last 40 minutes for 11 minutes
Any maintenance ?
Edit - Only ipv6 went down not NAT ipv4
It's HE tunneled ipv6 on your provisioned NAT node, they're probably having network blips.
Any maintenance ?
I have bought your VPS just while ago, but I have small issue. I have installed OpenVPN, it installed successfully, but the problem is openvpn app is connecting to it but internet not working afterwwards. Any solution please ??
Hi,
Can you access internet from inside the VPS (like try ping 1.1.1.1 from terminal)?
Just reinstall the OS & use this openvpn install script https://github.com/Nyr/openvpn-install enter one of your assigned ports when asked.
This script should work, as it always does.
Let me know.
Hi, Abdullah
I am installing from the same script that you mentioned above, when it is asking for IP address I am putting my IPV4 address, then port no: 18020 (my internal IP is eding with 180). for DNS I am using Google, UDP.. That how I am installing.
Pining is working fine even after installing OpenVPN on VPS
https://webhorizon.net
ok
Idea of "grab one, grab one" been bugging me for days. Paid the minimum $3.99 to release my brain.
Mine worked well, just enable tun from the panel.
@Abdullah It does not work. tried multiple times.
--I always need help..pff
Hi @xreann20
256MB NAT is currently out of stock in Singapore
This bundle is still available:
Also this: https://my.webhorizon.in/order/config/index/nat/?group_id=23&pricing_id=315
Order 604cb805008de
Thanks
Provisioned that, Thanks
I have an update if order link does not work for you:
New York and Switzerland are completely sold out, also the 5xbundle is outofstock.
Singapore is sold out for single NATs.
In stock:
VPS - NAT256 (Miami - US) - Order Link [ Coupon ClearNAT $3.99/y ]
VPS - NAT256 (Los Angeles - US) - Order Link [ Coupon ClearNAT $3.99/y ]
VPS - NAT256 (Dronten - NL) - Order Link [ Coupon ClearNAT $3.99/y ]
VPS - NAT256 (Mumbai - India) - Order Link [ Coupon N7YVRdNc $6.75/y ]
VPS - NAT256 (Tokyo - Japan) - Order Link [ Coupon 3vOiWfms $9.9/y ]
Ah man missed the bundle, Any chance of it returning?
not possible, Zurich & new york are out of stock.
