I guess you do not have enough ram for that distro, as far i know ubuntu 18.04 + is not go on 768mb, for other distros i have no idea there are no spech but know anything "new" ask a lot ram to mount ISO and finish install
You might do better from an iso as it doesn't need to buffer all the packages, etc....
I've checked all my emails and support tickets but found no order number. (Many guys said they got order number from one of them.) The only number I got is Invoice 1413507.
Please help me activate it if possible, or I request for a refund, in fact I prefer your service.
Thank you for your efforts!@VirMach
@realEthanZou said:
I mean to be patient but the FOMO is kicking in. I placed order 4767433618 on day 2 and it’s still not activated. Generally what’s the lead time?
Did you post your order ID here before? Maybe I missed it, I'll take a look now.
@knifered said:
Hi, I lost order id but only invoice:1414626. May U help me activate the VPS? I had sent message to your inbox, but no replay. Thanks.
regards,
@realEthanZou said: Node35. Performance of 3 cores isn't much better than 2 cores. And the network is kinda disappointing.
Maybe there are a lot of new deployments on that node and many are running yabs on a shared 1gb/s connection.
I would expect after most folks go into idle mode it will probably get better. Gota love that disk speed though
Due to my negligence, I forgot to save my order number. At present, I only have the invoice number: 1413457. Can you help me activate my VPS? thank you!
@VirMach said:
All order IDs should be activated. If you provided order ID and it's not activated, let me know. If you provided anything other than order ID, I can't immediately activate it right now but I'll probably go through each location in bulk anyway at some point in time so you'll receive your service most likely, you just have to be more patient.
@lechang said:
My Order Number is: 5363464785, please.
Excuse me, I guess you missed my order, may I have your attention please?
@Sean said: @VirMach
Order #560836
OrderNumber 8477795567
Invoice #1415112
Error 1015 Ray ID: 6fbcbb017883813f • 2022-04-14 13:18:58 UTC
You are being rate limited
What happened?
The owner of this website (solusvm.virmach.com) has banned you temporarily from accessing this website.
All I did was reset my password then try to get back to the login page to use it.
What happened?
Now it doesn't accept the new password. So I reset it again and get rate limited again.
What happened?
Order Number is: 2762579265
Thanks!
Order #560916
Sorry ,I lost my Order number, my invoice is 1414420. Please help me active it. Thank you!@VirMach
Order Number is: 7363285526 ,please open it .
I've just placed the order#561460,
Pls View Ticket :#364672,
Invoice#1416919,
Pls activate it as u see fit, thank u for ur effort!
Thank you!@VirMach
Order Number is: 6930100111
Thanks.
Twice. Thanks for the swift response this time.
@VirMach Sir! Help!
Maybe there are a lot of new deployments on that node and many are running yabs on a shared 1gb/s connection.![:smile: :smile:](https://staging.lowendspirit.com/plugins/emojiextender/emoji/twitter/smile.png)
I cannot find an order id , I got nothing after I paid.The only number I got is Invoice 1418055.
Please help me activate it if possible.
My Order Number is: 5013327118
Invoice #1418073
Please active it .
thanks.
Domain for Sale: Lea·com $3000,000 USD. Contact by email: [email protected]
I find out if lost the order number you can view the link to show the an order number:
https://billing.virmach.com/cart.php?a=complete
please。
It doesn't make sense.
I guess it's related with your cookies or sessions.
Order Number is: 8515385929 ,please open it .
Activation request. Order ID: 7173497678
My order is 7179813098, Pls help to activate. Thanks.
3 days uptime with 384MB RAM🥳
some benchmark results:
Now it doesn't accept the new password. So I reset it again and get rate limited again.![:/ :/](https://staging.lowendspirit.com/plugins/emojiextender/emoji/twitter/confused.png)
Try this
![](https://i.imgur.com/KSz1BY2.jpg)
@VirMach
Can I upgrade my order? Can 1536 upgrade 2560?Not enough memory。
