For domain registrations, create an account at Dynadot (ref) and spend $9.99 within 48 hours to receive $5 DynaDollars! Looking for cost-effective Managed/Anycast/DDoS-Protected/Geo DNS Services? Try ClouDNS (aff).
I mean, it could, I ran a vanilla forum on it myself before but you will find it pretty restrictive after a short amount of time, cant think it would be a great idea.
Running anything in shared gets restrictive very fast. Heck, even my WordPress stopped working after they updated their PHP and broke one of the poorly coded plugins. Had to move it to a VPS to make it work.
Ah ok, haven't ventured with vanilla for a long time?.
As soon the database gets fat, you gonna upgrade.
Just need to migrate a 1GB+ database from a 512MB KVM, was a bad idea.
@AnthonySmith is runcloud the one from runcloud.io?
We need an EPYC setup for future proof ?
@AnthonySmith, the CPU is too powerful for vanilla..
It feels like I'm accessing a forum in LAN
Accessing from Malaysia is really fast and was shock with the server specs
Thats cause the site is on cloudflare. So it got cached in the countries it is commonly accessed from.
And I have not even enabled rail gun yet
Yup.
I have to say it's loading really quick for me, have you upgraded it to 1G Ram yet?
@AnthonySmith
nope, I will say when I upgrade.
I wonder if it could fit in your shared hosting offer? Or does vanilla use own thing?
Appears to be running good so far. Looks good!
Todays update:
Looks like you've been doing some pruning; logrotate?
just general tidy ups.
Just vacuum that db once in a while, maybe from a late night cron task. Yes it does load fast, and I see very low ping, I guess because of cloudflare.
@AnthonySmith what storage engine are you using for MariaDB?
Today's update, I suppose i should stop doing this soon, maybe turn it weekly.
InnoDB.
@AnthonySmith what are you using for the graphs and monitoring?
Read through the tread it was mentioned.
Runcloud.
Or find a way to automate things? Anyway, please don't stop this kind of hosting / syadmin porn.
Today's update, if it was not clear, the vanilla stats (bottom) are 1 day behind.
That's a pretty rapid uptake, in my book. Still amazed at how little disc space is consumed, assuming it's still on 5GB.
By the end of the month there'll be 100K views and 300 users.
As attached images can be uploaded directly to the forum, I would also assume the consumed disk space to grow sooner or later.
