Yeah when I get the means I will be automating that through code, i.e. no links possible posts until 10+ posts and 7+ days registered, no wall posts either until a minimum threshold.
Also 0 post accounts will also no longer see the de'indexed stuff, 0 posts accounts older than 12 weeks will be auto purged etc.
yeah I know 2GB is overkill for this forum, but I figured that is probably the maximum it will ever need to run at peak and also run the backups at the same time without end user disruption.
@AnthonySmith said: Also 0 post accounts will also no longer see the de'indexed stuff, 0 posts accounts older than 12 weeks will be auto purged etc.
Thats a bit harsh....i enjoy reading while logged in....since i dont have much to talk or issue to discuss,thus not much/none posts were made...even on let,i made first post a few month after registered...and that when i have an issue with my server....
Sure I will do a bit longer range update, I just use runclouds stats, vanilla stats and google analytics.
@AnthonySmith If it is not too crazy to imagine that you can find the time, maybe it might be nice for everyone to see an updated version of the visitor analytics and also the server load statistics? Maybe for TLES and now also for the new LES site too?
Thanks....=D
You just posted so you are good for another 11 months now. That doesn’t seem harsh
Cheers
keep things tidy and accurate.
What are the updates now? And which monitoring tool are you using Ant?
⚆ ͜ʖ ͡⚆ Thanked by (1281): verjinSure I will do a bit longer range update, I just use runclouds stats, vanilla stats and google analytics.
Congrats on that decent resource usage.
Some stuff that I have running runs on quite big machina which is a big overkill.
Better let it run on small machina..
The usage is much less than I expect for running a forum.
Thanks....=D
MetalVPS
Cheers
VPS reviews and benchmarks |
Last 24 hours top 5 countries:
